BlueXP copy and sync APIs
The BlueXP copy and sync capabilities that are available through the web UI are also available through the RESTful API.
Getting started
To get started with the BlueXP copy and sync API, you need to obtain a user token and your BlueXP account ID. You'll need to add the token and account ID to the Authorization header when making API calls.
Obtain a user token from NetApp BlueXP.
POST https://netapp-cloud-account.auth0.com/oauth/token Header: Content-Type: application/json Body: { "username": "<user_email>", "scope": "profile", "audience": "https://api.cloud.netapp.com", "client_id": "UaVhOIXMWQs5i1WdDxauXe5Mqkb34NJQ", "grant_type": "password", "password": "<user_password>" }
If you are using a personal email account with no client ID, you can use the default client ID "QC3AgHk6qdbmC7Yyr82ApBwaaJLwRrNO.” |
Obtain your BlueXp account ID.
GET https://api.cloudsync.netapp.com/api/accounts Headers: Authorization: Bearer <user_token> Content-Type: application/json
This API will return a response like the following:
[ { "accountId": "account-JeL97Ry3", "name": "Test" } ]
Add the user token and account ID in the Authorization header of each API call.
Example
The following example shows an API call to create a data broker in Microsoft Azure. You would simply replace <user_token> and <accountId> with the token and ID that you obtained in the previous steps.
POST https://api.cloudsync.netapp.com/api/data-brokers Headers: Authorization: Bearer <user_token> Content-Type: application/json x-account-id: <accountId> Body: { "name": "databroker1", "type": "AZURE" }
API reference
Documentation for each BlueXP copy and sync API is available from https://api.cloudsync.netapp.com/docs.
Using list APIs
List APIs are asynchronous APIs, so the result does not return immediately (for example: GET /data-brokers/{id}/list-nfs-export-folders
and GET /data-brokers/{id}/list-s3-buckets
). The only response from the server is HTTP status 202. To get the actual result, you must use the GET /messages/client
API.
Call the list API that you want to use.
Use the
API to view the result of the operation. -
Use the same API by appending it with the ID that you just received:
GET http://api.cloudsync.netapp.com/api/messages/client?last=<id_from_step_2>
Note that the ID changes each time that you call the
API.
Example
When you call the list-s3-buckets
API, a result is not immediately returned:
GET http://api.cloudsync.netapp.com/api/data-brokers/<data-broker-id>/list-s3-buckets
The result is HTTP status code 202, which means the message was accepted, but was not processed yet.
To get the result of the operation, you need to use the following API:
The result is an array with one object that includes an ID field. The ID field represents the last message that the server sent. For example:
"header": {
"requestId": "init",
"clientId": "init",
"agentId": "init"
"payload": {
"init": {}
"id": "5801"
You would now make the following API call using the ID that you just received:
The result is an array of messages. Inside each message is a payload object, which consists of the name of the operation (as key) and its result (as value). For example:
"payload": {
"list-s3-buckets": [
"tags": [
"Value": "100$",
"Key": "price"
"region": {
"displayName": "US West (Oregon)",
"name": "us-west-2"
"name": "small"
"header": {
"requestId": "f687ac55-2f0c-40e3-9fa6-57fb8c4094a3",
"clientId": "5beb032f548e6e35f4ed1ba9",
"agentId": "5bed61f4489fb04e34a9aac6"
"id": "5802"
