BlueXP disaster recovery
Create a replication plan: Step 4 - Verify settings in BlueXP disaster recovery
Contributors amgrissino
After you add the replication plan information in BlueXP disaster recovery, verify that the information you entered is correct.
Steps
  1. Select Save to review your settings before activating the replication plan.
    You can select each tab to review the settings and make changes on any tab by selecting the pencil icon.
    Replication plan settings review Replication plan settings review
  2. When you are satisfied that all settings are correct, select Add plan at the bottom of the screen.
