Fixed issues in BlueXP edge caching
See what issues have been fixed in BlueXP edge caching.
27 March 2023 (version 2.2)
Fixed an issue of converting the time format of running a pre-population job for 'last modification time' option.
Fixed an issue related to parsing of file transfer and passing it on to Cloud Insights service.
Edge Sync of files across all subscribers is reconnected automatically when there is a disconnect with the publisher.
Fixed pre-population job execution on an Edge if its connected to multiple Cores.
Optimus UI now shows the connected Edge list on a publisher that participates in Edge Sync functionality.
24 October 2022 (version 2.1)
An additional validation of the GFC subscription number is performed during licensing configuration.
GFC added support to extend the license for a specific duration for Zuora-based licenses. Contact GFC support.
Added a 15 sec delay before writing a minidump after a crash. Also added a timer to monitor the minidump and forcibly exit the process if the dump does not complete in 60 secs. These minor enhancements will help for better analysis.
Removed individual file transfer information propagation to Cloud Insights, but added File transfer summary information propagation to Cloud Insights. This reduces enormous load on CI.
Fixed data and metadata ingestion into Cloud Insights. This enables for data visualization CI.
Fixed the Optimus Configuration UI to not hang while clicking the "Registering instance to CI" button.
Fixed an issue where the Tservice monitor is left manual during initial configuration.
Fixed minor bugs in the GFC CI Agent CLient service.
25 July 2022 (version 2.0)
Optimus is enhanced by adding boundary limits to date/time parameters for pre-population job addition configuration.
Optimus PSM now shows the correct CPU details in system pre-requisition details.
Fixed an exception in the UI during Edge Sync configuration between entering coordinator details and clicking the Refresh button.
Enhanced the Optimus UI to enable/disable the Edge Sync feature on the edge.
Fixed the date range issue in License Server Manager for Zuora License Aggregator.
Fixed the Optimus PSM to show Lease Count information.
Fixed License Management Server’s logic on configuration updater during an upgrade.
23 June 2022 (version 1.3.1)
Upon upgrade, the correct version of Microsoft re-distributable is not installed correctly and as a result Tum does not start. The GFC installer has been fixed to install the correct version re-distributable.
The GFC License Manager Service (LMS) now updates the configuration information, instead of overwriting it.
The Configuration UI now binds to the correct System.net.http dll during the upgrade process.
19 May 2022 (version 1.3.0)
The Configuration UI page for Edge Sync functionality is updated.
Fixed an issue when adding pre-population jobs for multiple Edges at the same time via PowerShell cmdlets.
Fixed a display issue in LMS Web UI that displays the NetApp subscription.
The LMS configuration PowerShell script now uses TLS 1.2.
Fixed an issue in TappN (pre-population service) and enabled it to continue executing the job, despite transient disconnections or Tum restarts.
The TappN pre-population service is updated to skip fetching files if free cache space falls below the lower threshold value.
Fixed an issue in the License Manager Server Service (LMS) while writing a trace log.
The Logging infrastructure for Tum is updated to be more scalable with high performance.
17 December 2021 (version 1.2.0)
The Configuration UI (Optimus) is enhanced to validate the date field entries while adding pre-population jobs.
Pre-population is enhanced to monitor cache utilization and will skip populating if cache usage reaches close to cache cleaner parameters.
Removed the hard dependency of the License Management Server (LMS) Service running locally with Policy configuration.
The GFC Kernel driver is enhanced to avoid a crash in the SMB Server service in Windows Server 2016/2019.
Fixed an exception in the LMS Service.
Service Start types for the License Manager Server Service (LMS), License Manager Client Service (LMC), and Pre-population Service (TappN) are changed from 'Automatic Delayed' to 'Automatic'.
