Manage Kubernetes clusters
You can use BlueXP to install or upgrade Astra Trident, configure storage classes, remove clusters, and enable data services.
Features
After adding Kubernetes clusters to BlueXP, you can manage the clusters from the resource page. To open the resource page, double-click the Kubernetes working environment on the Canvas.
A screenshot of the Kubernetes resource page showing details for the cluster.^
From the resource page you can:
Known limitation
Astra Trident deployed using tridentctl is not supported. If you deployed Astra Trident using tridentctl, you cannot use BlueXP to manage your Kubernetes clusters. You must uninstall using tridentctl and reinstall using the Trident operator or using BlueXP.
