Learn about tagging
BlueXP enables you to apply tags to your existing resources to help organize and manage those resources. Tags are metadata that you can use to group resources to identify applications, environments, regions, billing codes, cloud providers, and more.
Tags consists of a tag key and a tag value. For example, you can create a tag key called "Environment" and then add tag values of "Production" and "Test". After they are applied to your resources, you can quickly search for and view resources that match the key/value pair.
You can add tag key/value pairs to new resources when you create a working environment or an Azure NetApp Files volume. You can also define tag key/value pairs in BlueXP templates that you build for your storage admins and DevOps engineers.
You can add new tags using the Tagging service, and you can change or delete existing tags.
Features
The Tagging service offers the following features and benefits:
  • Create tag keys and tag values that match the terms you use in your environment
  • Organize the resources in your environment for easier monitoring and management
  • Add, remove, and edit tag keys and tag values by resource type
  • Tag ONTAP resources and resources in your environment from AWS and Azure.
Pricing and licenses
The ability to tag your resources requires no licensing and is free to use by all BlueXP users with the Account Admin or Workspace Admin role.
Resources that you can tag
You can apply tags to the following resources.
Provider Service Resource
ONTAP
Cloud Volumes ONTAP
Aggregate
Storage VM
Volume
On-premise ONTAP
Aggregate
Storage VM
Volume
Azure NetApp Files
Volume
NetApp-Service
Sync
Relationship
AWS
EC2
Instance
Security Group
Subnet
Volume
VPC
Azure
Compute
Snapshot
Virtual Machine
Network
Security Group
Virtual Network
Resource
Resource Group
Storage
Storage Account
GCP
Compute
Instance
Storage
Bucket
For information about AWS EC2 tags, refer to AWS Documentation: Tagging your Amazon EC2 Resources.
For information about Azure tags, refer to Azure Documentation: Tagging your Azure resources.
For information about Google labels, refer to Google Cloud Documentation: Tagging your Google Cloud resources.
Prerequisites
Verify your AWS Connector permissions
If you created the Connector using BlueXP version 3.9.10 or greater, then you’re all set. If you created the Connector using an earlier version of BlueXP, then you’ll need to add some required permissions for the BlueXP IAM role to tag AWS EC2 instances:
  "Action": [
    "ec2:CreateTags",
    "ec2:DeleteTags",
    "ec2:DescribeTags",
    "tag:getResources",
    "tag:getTagKeys",
    "tag:getTagValues",
    "tag:TagResources",
    "tag:UntagResources"
  "Resource": "*",
  "Effect": "Allow",
  "Sid": "tagServicePolicy"
Verify your Azure Connector permissions
If you created the Connector using BlueXP version 3.9.10 or greater, then you’re all set. If you created the Connector using an earlier version of BlueXP, then you’ll need to add some required permissions for the BlueXP Operator IAM role to tag Azure resources:
  "id": "<ID>",
  "properties": {
    "roleName": "Cloud Manager Operator-<ID>",
    "description": "Cloud Manager Operator",
    "assignableScopes": [
      "/subscriptions/<SUBSCRIPTION-ID>"
    "permissions": [
        "actions": [
          "Microsoft.Resources/tags/read",
          "Microsoft.Resources/tags/write",
          "Microsoft.Resources/tags/delete",
          "Microsoft.ClassicCompute/virtualMachines/read"
        "notActions": [],
        "dataActions": [],
        "notDataActions": []
Tag rules and restrictions
The following rules apply when creating tag keys and tag values:
  • Maximum key length: 128 characters
  • Maximum key value length: 256 characters
  • Valid tag and tag value characters: letters, numbers, spaces, and special characters (_, @, &, *, etc.)
  • Tags are case upper/lower sensitive.
  • Maximum tags per resource: 30
  • Per resource, each tag key must be unique
Tag examples
Key Values
Env
production
test
Dept
finance
sales
eng
Owner
admin
storage
