Build application templates for your organization
Select one or more of the NetApp-provided "actions" and quickly build an application template that your organization can use to start optimizing the creation of resources.
Quick start
Get started quickly by following these steps, or scroll down to the remaining sections for full details.
Before users can create a volume for a Cloud Volumes ONTAP, on-premises ONTAP, or Azure NetApp Files system using a template, make sure they have access to an appropriate working environment where the volume will be deployed.
If you plan to add a Cloud service "action" to your template, such as BlueXP backup and recovery or BlueXP classification, ensure that the service is active and licensed in your environment.
Select Health > Remediation, click the Editor tab, and select the actions you’ll use in your template.
Follow the creation steps and define the actions that will be performed by the template.
Requirements
Read the following requirements to make sure that you have a supported configuration.
If you don’t already have a Connector, see how to create Connectors for AWS, Azure, and GCP.
When creating a Cloud Volumes ONTAP volume template, make sure you have a Cloud Volumes ONTAP working environment available for your users. See how to launch a Cloud Volumes ONTAP system in AWS, Azure, or in GCP.
When creating an on-premises ONTAP volume template, make sure you have an on-premises ONTAP working environment available for your users. See how to discover an on-premises ONTAP system in BlueXP.
When creating an Azure NetApp Files volume template, make sure you have an Azure NetApp Files working environment available for your users. See how to create an Azure NetApp Files working environment in BlueXP.
If you plan to use BlueXP backup and recovery to backup up a volume in the template, ensure that your environment has activated BlueXP backup and recovery.
If you plan to use BlueXP classification to scan volumes in the template, ensure that your environment has activated BlueXP classification.
If you plan to enable BlueXP replication in the template, and the template is for an on-premises ONTAP volume, the ONTAP cluster must have an active SnapMirror license.
Examples of creating resources using templates
Resource templates enable you to create new volumes or a new Cloud Volumes ONTAP working environment.
Create a template for a Cloud Volumes ONTAP volume
See how to provision Cloud Volumes ONTAP volumes for details about all the parameters you need to complete in the Cloud Volumes ONTAP volume template.
For this example we’ll create a template named "CVO volume for databases" and include the following 2 actions:
Create Cloud Volumes ONTAP Volume
Make the volume for the AWS environment, configure it with 100 GB of storage, set the Snapshot Policy to "default", and enable Storage Efficiency.
Enable BlueXP backup and recovery
Create 30 daily, 13 weekly, and 3 monthly backups (using the 3 Months Retention policy).
Select Health > Remediation, click the Templates tab, and click Add New Template.
The Select_a Template page is displayed.
Select Volume for Cloud Volumes ONTAP + Backup as the type of resource you want to create, and click Get Started.
The Create Volume in Cloud Volumes ONTAP Action Definition page is displayed.
Action Name: Optionally, enter a customized action name instead of the default value.
Context: Enter the Cloud Volumes ONTAP working environment context; if required.
When users launch the template from an existing working environment, this information gets filled in automatically.
When users launch the template from the Templates Dashboard (not in a working environment context), then they need to select the working environment and the SVM where the volume will be created. That’s why these fields are marked as "Editable".
Details: Enter the volume name and size.
Field Description Volume Name
Click in the field and select one of the 5 options. You can let the admin enter any name by selecting Free Text, or you can specify that the volume name must have a certain prefix or suffix, that it contains certain characters, or that it follows rules from a regular expression (regex) you enter.
For example, you could specify that "db" be a required prefix, suffix, or contains; requiring the user to add volume names like "db_vol1", "vol1_db", or "vol_db_1".Volume Size
You can specify a range of allowable values, or you can specify a fixed size. This value is in GB. For our example we can add a fixed value 100.
Tags
Enter a name and value pair for a tag that you want to associate with this volume. For example, you could add "Cost Center" as the tag name and the cost center code "6655829" as the value. You can associate more than one tag with a volume by adding more tag name and value pairs.
Protection: Choose whether this volume will have Snapshot copies created by selecting "Default" or some other policy, or choose "None" if you do not want to create Snapshot copies.
Usage Profile: Choose whether or not NetApp storage efficiency features are applied to the volume. This includes Thin Provisioning, Deduplication, and Compression. For our example, keep storage efficiency enabled.
Disk Type: Choose the cloud storage provider and the type of disk. For some disk selections you can also select a minimum and maximum IOPS or Throughput (MB/s) value; basically defining a certain Quality of Service (QoS).
Protocol Options: Select NFS or SMB to set the protocol of the volume. And then the provide the protocol details.
NFS Fields Description Access Control
Choose whether access controls are needed to access the volume.
Export Policy
Create an export policy to define the clients in the subnet that can access the volume.
NFS Version
Select the NFS version for the volume: either NFSv3 or NFSv4, or you can select both.
SMB Fields Description Share Name
Click in the field and select one of the 5 options. You can let the admin enter any name (Free Text) or you can specify that the share name must have a certain prefix or suffix, that it contains certain characters, or that it follows rules from a regular expression (regex) you enter.
Permissions
Select the level of access to a share for users and groups (also called access control lists, or ACLs).
Users / Groups
Specify local or domain Windows users or groups, or UNIX users or groups. If you specify a domain Windows user name, you must include the user’s domain using the format domain\username.
Tiering: Choose the tiering policy that you would like applied to the volume, or set this to "None" if you do not want to tier cold data from this volume to object storage.
See volume tiering policies for an overview, and see Tiering inactive data to object storage to make sure your environment is set up for tiering.
Click Apply after you have defined the parameters needed for this action.
If the template values are correctly completed, a green checkmark is added to the "Create Volume in Cloud Volumes ONTAP" box.
Click the Enable Cloud Backup on Volume box and the Enable Cloud Backup on Volume Action Definition dialog is displayed so you can fill in the BlueXP backup and recovery details.
Select the 3 Months Retention backup policy to create 30 daily, 13 weekly, and 3 monthly backups.
Below the Working Environment and Volume Name fields there are three selections you use to indicate which volume will have backup enabled. See how to complete these fields.
Click Apply and the BlueXP backup and recovery dialog is saved.
Enter the template name CVO volume for databases (for this example) in the top left.
Click Settings & Drift to provide a more detailed description so that this template can be distinguished from other similar templates, and so you can enable Drift for the overall template, and then click Apply.
Drift allows BlueXP to monitor the hard-coded values you entered for parameters when creating this template.
Click Save Template.
The template is created and you are returned to the Templates Dashboard where your new template appears.
Create a template for an Azure NetApp Files volume
Creating a template for an Azure NetApp Files volume is done in the same manner as creating a template for a Cloud Volumes ONTAP volume.
See how to provision Azure NetApp Files volumes for details about all the parameters you need to complete in the ANF volume template.
Select Blank template and click Get Started.
Select Create Volume in Azure NetApp Files as the type of resource you want to create, and click Apply.
The Create Volume in Azure NetApp Files Action Definition page is displayed.
Volume Details: Enter a volume name and size, and optionally specify tags for the volume.
Tags
Protocol: Select NFSv3, NFSv4.1, or SMB to set the protocol of the volume. And then the provide the protocol details.
NFS Fields Description Volume Path
Select one of the 5 options. You can let the admin enter any path by selecting Free Text, or you can specify that the path name must have a certain prefix or suffix, that it contains certain characters, or that it follows rules from a regular expression (regex) you enter.
Export Policy Rules
SMB Fields Description Volume Path
Context: Enter the Azure NetApp Files working environment, details for a new or an existing Azure NetApp Files account, and other details.
Field Description Working Environment
When storage admin users launch the template from an existing working environment, this information gets filled in automatically.
When users launch the template from the Templates Dashboard (not in a working environment context), then they need to select the working environment where the volume will be created.NetApp Account Name
Enter the name you want to use for the account.
Azure Subscription ID
Enter the Azure Subscription ID. This is the full ID in a format similar to "2b04f26-7de6-42eb-9234-e2903d7s327".
Region
Enter the region using the internal region name.
Resource Group Name
Enter the name of the Resource Group you want to use.
Capacity Pool Name
Enter the name of an existing capacity pool.
Subnet
Enter the VNet and subnet. This value includes the full path, in a format similar to "/subscriptions/<subscription_id>/resourceGroups/<resource_group>/ providers/Microsoft.Network/virtualNetworks/<vpc_name>/subnets/<subhet_name>".
Snapshot Copy: Enter the Snapshot ID for an existing volume Snapshot if you want this new volume to be created using characteristics from an existing volume.
Enter the name you want to use for the template in the top left.
Create a template for an on-premises ONTAP volume
See how to provision on-premises ONTAP volumes for details about all the parameters you need to complete in the on-premises ONTAP volume template.
The Add New Action page is displayed.
Select Create Volume in On-Premises ONTAP as the type of resource you want to create, and click Apply.
The Create Volume in On-Premises ONTAP Action Definition page is displayed.
Context: Enter the on-premises ONTAP working environment context; if required.
When users launch the template from the Templates Dashboard (not in a working environment context), then they need to select the working environment, the SVM, and the aggregate where the volume will be created.
Tags
Export Policy
NFS Version
Permissions
Users / Groups
If the template values are correctly completed, a green checkmark is added to the "Create Volume in On-Premises ONTAP" box.
Enter the template name in the top left.
The template is created and you are returned to the Template Dashboard where your new template appears.
Create a template for a Cloud Volumes ONTAP working environment
You can create a single-node or high-availability Cloud Volumes ONTAP working environment using templates.
See how to launch a single-node Cloud Volumes ONTAP system in AWS or a Cloud Volumes ONTAP HA pair in AWS for the prerequisites that must be in place, and for details about all the parameters you’ll need to define in this template.
Select Create Working Environment in AWS (single node) or Create Working Environment in AWS (high availability) as the type of resource you want to create, and click Apply.
For this example, the Create Working Environment in AWS (single node) page is displayed.
Details and Credentials: Select the AWS credentials to use, enter a working environment name, and add tags, if needed.
Some of the fields in this page are self-explanatory. The following table describes fields for which you might need guidance:
Field Description Credentials
These are the credentials for the Cloud Volumes ONTAP cluster admin account. You can use these credentials to connect to Cloud Volumes ONTAP through ONTAP System Manager or its CLI.
Working Environment Name
BlueXP uses the working environment name to name both the Cloud Volumes ONTAP system and the Amazon EC2 instance. It also uses the name as the prefix for the predefined security group, if you select that option.
Click in the field and select one of the 5 options. You can let the admin enter any name by selecting Free Text, or you can specify that the working environment name must have a certain prefix or suffix, that it contains certain characters, or that it follows rules from a regular expression (regex) you enter.Tags
AWS tags are metadata for your AWS resources. BlueXP adds the tags to the Cloud Volumes ONTAP instance and each AWS resource associated with the instance.
For information about tags, refer to AWS Documentation: Tagging your Amazon EC2 Resources. -
Location & Connectivity: Enter the network information that you recorded in the AWS worksheet. This includes the AWS Region, VPC, Subnet, and Security Group.
If you have an AWS Outpost, you can deploy a single node Cloud Volumes ONTAP system in that Outpost by selecting the Outpost VPC. The experience is the same as any other VPC that resides in AWS.
Authentication Method: Select the SSH authentication method you want to use; either a password or a key pair.
Data Encryption: Choose no data encryption or AWS-managed encryption.
For AWS-managed encryption, you can choose a different Customer Master Key (CMK) from your account or another AWS account.
Charging Method: Specify which charging option would you like to use with this system.
NetApp Support Site Account: Select a NetApp Support Site account.
Preconfigured Packages: Select one of the four preconfigured packages that will determine several factors for volumes created in the working environment.
SMB Configuration: If you plan to deploy volumes using SMB on this working environment, you can set up a CIFS server and related configuration elements.
If the template values are correctly completed, a green checkmark is added to the "Create Working Environment in AWS (single node)" box.
You may want to add another action in this template to create a volume for this working environment. If so, click
and add that action. See how to create a template for a Cloud Volumes ONTAP volume for details.
Examples of finding existing resources using templates
Using the Find Existing Resources action you can find specific working environments or find existing volumes by providing a variety of filters so you can narrow your search to just the resources you are interested in. After finding the correct resources, you can add volumes to a working environment, or enable a cloud service on the resulting volumes.
At this time you can find volumes within Cloud Volumes ONTAP, on-premises ONTAP, and Azure NetApp Files systems. And you can enable BlueXP backup and recovery on Cloud Volumes ONTAP and on-premises ONTAP volumes. Additional resources and services will be available at a later time. |
Find existing volumes and activate a cloud service
The current Find Existing Resources action functionality enables you to find volumes on Cloud Volumes ONTAP and on-premises ONTAP working environments that do not currently have BlueXP backup and recovery or BlueXP classification enabled. When you enable BlueXP backup and recovery on specific volumes, this action also sets the backup policy you configured as the default policy for that working environment - so all future volumes on those working environments can use the same backup policy.
Select Find Existing Resources as the type of action you want to define, and click Apply.
The Find Existing Resources Action Definition page is displayed.
Action Name: Enter a customized action name instead of the default value. For example, "Find large volumes on cluster ABC and enable Backup".
Resource Type: Select the type of resource you want to find. In this case you might select Volumes in Cloud Volumes ONTAP.
This is the only required entry for this action. You could click Continue now and you’ll receive a list of all volumes on all Cloud Volumes ONTAP systems in your environment.
Instead, it is recommended that you fill out a few filters to reduce the number of results (in this case, volumes) on which you’ll apply the BlueXP backup and recovery action.
In the Context area you can select a specific working environment and some other details about that working environment.
In the Details area you can select the volume name, the volume size range, and any tags assigned to the volumes.
For the volume name, click in the field and select one of the 5 options. You can let the admin enter any name by selecting Free Text, or you can specify that the volume name must have a certain prefix or suffix, that it contains certain characters, or that it follows rules from a regular expression (regex) you enter.
For volume size you can specify a range; for example, all volumes between 100 GiB and 500 GiB.
For tags you can narrow the search further so that the results display only volumes with certain tag key/value pairs.
Click Continue and the page updates to show the Search Criteria that you’ve defined in the template.
Click Test your search criteria now to see the current results.
If the results are not what you expected, click
next to Search Criteria and refine your search further.
When the results are good, click Done.
Your completed Find Existing Resources action appears in the editor window.
Click the Plus sign to add another action, select Enable Cloud Backup On Volume, and click Apply.
The Enable Cloud Backup On Volume action is added to the window.
Now you can define the Backup criteria as described in Adding Backup functionality to a volume so that the template applies the correct backup policy to the volumes you select from the Find Existing Resources action.
Click Apply to save the customization you made to the Backup action, and then click Save Template when you are done.
Find existing working environments
Using the Find Existing Resources action you can find the working environment, and then use other template actions, such as creating a volume, to easily perform actions on the existing working environment.
Action Name: Enter a customized action name instead of the default value. For example, "Find work environments that include Dallas".
Resource Type: Select the type of resource you want to find. In this case you would select Working Environments.
This is the only required entry for this action. You could click Continue now and you’ll receive a list of all working environments in your environment.
Instead, it is recommended that you fill out a few filters to reduce the number of results (in this case, working environments).
After defining a few filters in the Details area, you can select a specific working environment.
Click Continue to save your settings, and then click Done.
Enter the template name in the top left, and then click Save Template
Examples of enabling services using templates
Service templates enable you to activate BlueXP backup and recovery, BlueXP classification, or BlueXP replication (SnapMirror) services on a newly created volume.
Add Backup functionality to a volume
When creating a volume template, you can add in the template that you want to create backups of the volume periodically using the BlueXP backup and recovery service.
This action is not applicable for Azure NetApp Files volumes. |
Policy: Select the backup policy that you want to use.
Context: By default, the variables are filled out for the working environment, storage VM, and volume to indicate that you will be creating backups for the volume created previously in this same template. So if that’s what you want to do, you’re all set.
If you want to create backups for a different volume, you can enter those details manually. See how to complete the Context fields to indicate a different volume.
Click Apply to save your changes.
Add BlueXP classification functionality to a volume
When creating a volume template, you can add in the template that you want to scan the volume for compliance and classification using the BlueXP classification service.
Context: By default, the variables are filled out for the working environment, volume name, volume UUID, volume path, and protocol to indicate that you will be scanning data for the volume created previously in this same template. So if that’s what you want to do, you’re all set.
If you want to scan data for a different volume, you can enter those details manually. See how to complete the Context fields to indicate a different volume.
Add BlueXP replication functionality to a volume
When creating a volume template, you can add in the template that you want to replicate the data in the volume to another volume using the BlueXP replication service. You can replicate data to a Cloud Volumes ONTAP cluster or to an on-prem ONTAP cluster.
BlueXP replication functionality consists of three parts: selecting the source volume, selecting the destination volume, and defining the replication settings. Each section is described below.
Source Details: Enter the details about the source volume you want to replicate:
By default, the first three variables are filled out for the working environment, storage VM, and volume to indicate that you will be replicating the volume created previously in this same template. So if that’s what you want to do, you’re all set.
If you want to replicate a different volume, you can enter those details manually. See how to complete the Context fields to indicate a different volume.
BlueXP replication requires that the source and destination working environments are connected through their intercluster LIFs. Enter the intercluster LIF IP address for the source working environment.
To get this information: double-click the working environment, click the menu icon, and click Information.
Destination Details: Enter the details about the destination volume that will be created by the replication operation:
Select the working environment where the volume will be created.
Select the storage VM on which the volume will reside.
When replicating a volume to a Cloud Volumes ONTAP cluster (not to an on-prem ONTAP cluster), you need to specify the Destination Provider (AWS, Azure, or GCP).
When replicating a volume to a Cloud Volumes ONTAP cluster, you can specify whether volume tiering is enabled on the destination volume.
For the destination volume name, click in the field and select one of the 5 options. You can let the admin enter any name by selecting Free Text, or you can specify that the volume name must have a certain prefix or suffix, that it contains certain characters, or that it follows rules from a regular expression (regex) you enter.
BlueXP replication requires that the source and destination working environments are connected through their intercluster LIFs. Enter the intercluster LIF IP address for the destination working environment.
Select the aggregate on which the volume will reside.
When replicating a volume to a Cloud Volumes ONTAP cluster (not to an on-prem ONTAP cluster), you need to specify the type of disk that will be used for the new volume.
Replication Details: Enter the details about the type and frequency of the replication operation:
Select the replication policy that you want to use.
Choose a one-time copy or a recurring replication schedule.
Enable replication health status monitoring if you want the drift report to include the replication health of the SnapMirror relationship along with the lag time, status, and last transfer time. See what this looks like in the drift report.
Select whether you want to set a transfer rate limit, and then enter the maximum rate (in kilobytes per second) at which data can be transferred. You can enter a fixed value, or you can provide a minimum and maximum and let the storage admin select a value in that range.
What to do after you have created the template
After you have created a template, you should inform your storage administrators to use the template when creating new working environments and volumes.
You can point them to Creating resources using templates for details.
Edit or delete a template
You can modify a template if you need to change any of the parameters. After you save your changes, all future resources created from the template will use the new parameter values.
You can also delete a template if you no longer need it. Deleting a template does not affect any of the resources that were created with the template. However, no Drift compliance checking can be done after the template is deleted.
Make a copy of a template
You can create a copy of an existing template. This can save a lot of time in case you want to create a new template that is very similar to an existing template. Just make the duplicate with a new name, and then you can edit the template to change the couple items that make the template unique.
