Sign up to BlueXP
BlueXP is accessible from a web-based console. When you get started with BlueXP, your first step is to sign up using your existing NetApp Support Site credentials or by creating a NetApp cloud login.
You can sign up to BlueXP using one of the following options:
Your existing NetApp Support Site (NSS) credentials
A NetApp cloud login by specifying your email address and a password
Both options support a federated connection, which enables single sign-on using credentials from your corporate directory (federated identity). You can set up a federation connection after you sign up. Learn how to use identity federation with BlueXP.
Open a web browser and go to the BlueXP console
If you have a NetApp Support Site account, enter the email address associated with your NSS account directly on the Log in page.
You can skip the sign up page if you have an NSS account. BlueXP will sign you up as part of this initial login.
If you don't have an NSS account and you want to sign up by creating a NetApp cloud login, select Sign up.
On the Sign up page, enter the required information to create a NetApp cloud login.
Note that only English characters are allowed in the sign up form.
When prompted, review the End User License Agreement and accept the terms.
On the Welcome page, enter a name for your account.
If your business already has an account and you want to join it, then you should close out of BlueXP and ask the owner to associate you with the account. After the owner adds you, you can log in and you'll have access to the account. Learn how to add members to an existing account.
An account is the top-level element in NetApp's identity platform. It enables you to add and manage users, roles, permissions, and working environments.
Select Create Account.
You now have a BlueXP login and an account. In most cases, the next step is to create a Connector, which connects BlueXP's services to your hybrid cloud environment.
