Set up licensing for NetApp Cloud Tiering
NetApp Cloud Tiering is no longer available for purchase or license renewal as of April 26, 2026.
NetApp Cloud Tiering is no longer available for purchase or license renewal as of April 26, 2026. Existing customers can continue to use and receive support for NetApp Cloud Tiering until their subscription or license contract expires. After the subscription expires, customers will no longer have access to NetApp Cloud Tiering features or support. NetApp recommends customers work with their NetApp representative to transition their existing tiering licenses to ONTAP FabricPool licenses, which provides the functionality for data tiering in ONTAP. See Install a FabricPool license on an ONTAP cluster for more information on how to set up data tiering in ONTAP using FabricPool. |
If you are currently using Cloud Tiering licensing, you're not affected until your Cloud Tiering license reaches its expiration date or maximum capacity. Contact NetApp when you need to update your license, or earlier to make sure there is no interruption in your ability to tier data to the cloud.
