NetApp Console setup and administration
Console agent firewall rules in Google Cloud
Contributors netapp-tonias
The Google Cloud firewall rules for the agent requires both inbound and outbound rules. The NetApp Console automatically creates this security group when you create a Console agent from the Console. for other installation options, you need to set up this security group manually.
Inbound rules
Protocol Port Purpose
SSH
22
Provides SSH access to the agent host
HTTP
80
  • Provides HTTP access from client web browsers to the local user interface
  • Used during the Cloud Volumes ONTAP upgrade process
HTTPS
443
Provides HTTPS access from client web browsers to the local user interface
TCP
3128
Provides Cloud Volumes ONTAP with internet access. You must manually open this port after deployment.
Outbound rules
The agent's predefined firewall rules open all outbound traffic. Follow basic outbound rules if acceptable, or use advanced outbound rules for stricter requirements.
Basic outbound rules
The predefined firewall rules for the agent include the following outbound rules.
All TCP
All
All outbound traffic
All UDP
All
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by the agent.
Note The source IP address is the agent host.
Service Protocol Port Destination Purpose
API calls and AutoSupport
HTTPS
443
Outbound internet and ONTAP cluster management LIF
API calls to Google Cloud, to ONTAP, to NetApp Data Classification, and sending AutoSupport messages to NetApp
API calls
TCP
8080
Data Classification
Probe to Data Classification instance during deployment
DNS
UDP
53
DNS
Used for DNS resolve by Data Classification
