Creating annotation rules Edit on GitHub Request doc changes
Contributors dgracenetapp netapp-alavoie
You can use annotation rules to automatically apply annotations to multiple assets based on criteria that you define. Cloud Insights assigns the annotations to assets based on these rules. Annotations set manually on an individual asset pages take precedence over rule-based annotations when Cloud Insight evaluates the annotation rules.
Before you begin
You must have created a query for the annotation rule.
Steps
  1. In the Cloud Insights menu click Manage > Annotation rules.
    The Add Rule dialog is displayed.
  2. Do the following:
    1. In the Name box, enter a unique name that describes the rule.
      The name appears in the Annotation Rules page.
    2. Click Query and select the query that Cloud Insights uses to identify the assets the annotation applies to.
    3. Click Annotation and select the annotation you want to apply.
    4. Click Value and select a value for the annotation.
      For example, if you choose Birthday as the annotation, you specify a date for the value.
    5. Click Save
    6. Click Run all rules if you want to run all the rules immediately; otherwise, the rules are run at a regularly scheduled interval.
Modifying annotation rules
You can modify an annotation rule to change the rule’s name, its annotation, the annotation’s value, or the query associated with the rule.
Steps
  1. In the Cloud Insights menu, Click Manage > Annotation rules.
    The Annotation Rules page displays the list of existing annotation rules.
  2. Locate the Annotation Rule you want to delete.
    Filter the annotation rules by entering a value in the filter box or click a page number to browse through the annotation rules by page.
  3. Click the menu icon for the rule that you want to modify.
  4. Click Modify
    The Edit Rule dialog is displayed.
  5. Modify the annotation rule’s name, annotation, value, or query.
Deleting annotation rules
You might want to delete annotation rules that are no longer used
Steps
  3. Click the menu icon for the rule that you want to delete.
  4. Click Delete
    A confirmation message is displayed, prompting whether you want to delete the rule.
  5. Click OK
