Brocade FC Switch data collector Edit on GitHub Request doc changes
Cloud Insights uses the Brocade FC Switch (SSH) data source to discover inventory for Brocade or rebranded switch devices running Factored Operating System (FOS) firmware 4.2 and later. Devices in both FC switch and Access Gateway modes are supported.
Terminology
Cloud Insights acquires the following inventory information from the Brocade FC Switch data collector. For each asset type acquired by Cloud Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Switch Switch
Port
Port
Virtual Fabric, Physical Fabric
Fabric
Zone
Zone
Logical Switch
Logical Switch
Virtual Volume
Volume
LSAN Zone
IVR Zone
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • There must be IP connectivity to all switches in the fabric. If you select the Discover all switches in the fabric check box, Cloud Insights identifies all the switches in the fabric; however, it needs IP connectivity to these additional switches to discover them.
  • The same account is needed globally across all switches in the fabric. You can use PuTTY (open source terminal emulator) to confirm access.
  • Ports 161 and 162 must be open to all switches in the fabric for SNMP performance polling.
  • SNMP read-only Community String
Configuration
Field Description
Switch IP
IP address or fully-qualified domain name of the EFC Server
User Name
User name for the switch
Password
Password for the switch
SNMP
SNMP version
SNMP Community String
SNMP read-only community string used to access the switch
SNMP User Name
SNMP user name
SNMP Password
SNMP password
Advanced configuration
Field Description
Fabric name
Fabric name to be reported by the data collector. Leave blank to report the fabric name as WWN.
Inventory Poll Interval (min)
Interval between inventory polls. The default is 15.
Excluded Devices
Comma-separated list of device IDs to exclude from polling
Timeout (sec)
Connection timeout. The default is 30.
Banner Wait Timeout (sec)
SSHAdmin Domains Active Select if using Admin Domainsbanner wait timeout. The default is 5 seconds.
Retrieve MPR Data
Select to acquire routing data from your multiprotocol router.
Enable Trapping
Select to enable acquisition upon receiving an SNMP trap from the device. If you select enable trapping, you must also activate SNMP.
Minimum Time Between Traps (sec)
Minimum time between acquisition attempts triggered by traps. The default is 10.
Select to discover all switches in the fabric
Choose Favoring HBA vs. Zone Aliases
Choose whether to favor HBA or zone aliases
Performance Poll Interval (sec)
Interval between performance polls. The default is 300.
SNMP Auth Protocol
SNMP authentication protocol (SNMP v3 only)
SNMP Privacy Password
SNMP privacy password (SNMP v3 only)
SNMP Retries
Number of SNMP retry attempts
SNMP Timeout (ms)
SNMP timeout. The default is 5000.
