Ceph storage data collector
Contributors netapp-alavoie Download PDF of this page
Cloud Insights uses the Ceph storage data collector to discover inventory data from the Ceph storage platform.
Terminology
Cloud Insights acquires inventory information with the Ceph storage data collector. For each asset type acquired by Cloud Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Cloud Insights Term
Pool
Storage Pool
FileSystem
Internal Volume
OSD
Backend LUN
Note: These are common terminology mappings only and might not represent every case for this data source.
Requirements
  • The Ceph administrator IP address
  • Administrator user name and password
  • Port requirement: SSH Port 22
Configuration
Field Description
Ceph admin IP address
Ip address for the for the Ceph storage
User name
User name for the Ceph storage system administrator user account
Password
Password for the administrator user account
Advanced configuration
Field Description
Inventory poll interval (min)
Interval between inventory polls. The default is 60 minutes.
SSH port
The default is port 22.
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
Command missing
Verify that the user has permissions to run the commands noted below on the device
* Verify that the ceph adminstration tools are installed, please run the following command: rpm -q ceph-common.x86_64
* Verify credentials used in the wizard match device credentials
Invalid configuration
* Verify that the pools are configured in the system, try running the following command: ceph osd lspools -f json-pretty
Additional information may be found from the Support page or in the Data Collector Support Matrix.
