HPE Nimble data collector
Download PDF of this page
The HPE Nimble data collector supports inventory and performance data for HPE Nimble storage arrays.
Terminology
Cloud Insights acquires the following inventory information from the HPE Nimble data collector. For each asset type acquired by Cloud Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term | Cloud Insights Term |
Array |
Storage |
Disk |
Disk |
Volume |
Volume |
Pool |
Storage Pool |
Initiator |
Storage Host Alias |
Controller |
Storage Node |
Fibre Channel Interface |
Controller |
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
You must have the following in order to collect inventory and configuration data from the Nimble storage array:
The array must be installed and configured, and reachable from the client through its fully qualified domain name (FQDN) or array management IP address.
The array must be running NimbleOS 2.3.x or later.
You must have a valid user name and password to the array with at least "Operator" level role. The "Guest" role does not have sufficient access to understand initiator configurations.
Port 5392 must be open on the array.
You must have the following in order to collect performance data from the Nimble storage array:
The array must be running NimbleOS 4.0.0 or later
The array must have volumes configured. The only performance API NimbleOS has is for volumes, and any statistics Cloud Insights reports are derived from the statistics on volumes
Configuration
Field | Description |
Array Management IP Address |
Fully qualified domain name (FQDN) or array management IP address. |
User Name |
User name for the Nimble array |
Password |
Password for the Nimble array |
Advanced configuration
Field |
Description |
Port |
Port used by Nimble REST API. The default is 5392. |
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 60 minutes. |
Note: The default performance poll interval is 300 seconds and can not be changed. This is the only interval supported by Nimble.
