English
ONTAP Data Management data collector
Contributors netapp-alavoie
This data collector acquires inventory and performance data from storage systems running ONTAP Data management software using read-only API calls from an administrator account.
Terminology
Cloud Insights acquires inventory and performance data from the ONTAP Data management software data collector. For each asset type acquired, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Cloud Insights Term
Disk
Disk
Raid Group
Disk Group
Cluster
Storage
Node
Storage Node
Aggregate
Storage Pool
LUN
Volume
Volume
Internal Volume
Requirements
The following are requirements to configure and use this data collector:
  • You must have access to an Administrator account used for read-only API calls.
  • Target IP is the cluster management LIF.
  • FCP license and mapped/masked volumes required for Cloud Insights discovery.
  • CIFS and/or NFS license and CIFS shares or NFS exports required for Cloud Insights NAS discovery.
  • Access validation: Telnet or SSH to the cluster management LIF from the acquisition unit, using the username and password.
Configuration
Field Description
NetApp Management IP
IP address or fully-qualified domain name of the NetApp cluster
User Name
User name for NetApp cluster
Password
Password for NetApp cluster
Advanced configuration
Field Description
Connection Type
HTTPS or HTTP, also displays the default port
Override Connection Port
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use
Inventory Poll Interval (min)
Default is 20 minutes.
Performance Poll Interval (sec)
Default is 300 seconds.
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
Receive 401 HTTP response or 13003 ZAPI error code and ZAPI returns “Insufficient privileges” or “not authorized for this command”
Check username and password, and user privileges/permissions.
Cluster version is < 8.1
Cluster minimum supported version is 8.1. Upgrade to minimum supported version.
ZAPI returns "cluster role is not cluster_mgmt LIF"
AU needs to talk to cluster management IP. Check the IP and change to a different IP if necessary
Error: “7 Mode filers are not supported”
This can happen if you use this data collector to discover 7 mode filer. Change IP to point to cdot filer instead.
ZAPI command fails after retry
AU has communication problem with the cluster. Check network, port number, and IP address. User should also try to run a command from command line from the AU machine.
AU failed to connect to ZAPI via HTTP
Check whether ZAPI port accepts plaintext. If AU tries to send plaintext to an SSL socket, the communication fails.
Communication fails with SSLException
AU is attempting to send SSL to a plaintext port on a filer. Check whether the ZAPI port accepts SSL, or use a different port.
Additional Connection errors:
ZAPI response has error code 13001, “database is not open”
ZAPI error code is 60 and response contains “API did not finish on time”
ZAPI response contains “initialize_session() returned NULL environment”
ZAPI error code is 14007 and response contains “Node is not healthy”
Performance
Problem: Try this:
“Failed to collect performance from ZAPI” error
This is usually due to perf stat not running. Try the following command on each node:
> system node systemshell -node * -command “spmctl -h cmd –stop; spmctl -h cmd –exec”
Additional information may be found from the Support page or in the Data Collector Support Matrix.
