Set up ONTAP alerts in NetApp Console
To use ONTAP alerts, perform a few steps to set it up.
Before you begin, review prerequisites to ensure that your environment is ready.
Access to cluster resources
To view the alerts, the logged-in user must be part of the NetApp Console organization and should have the required access to the cluster resource.
Create the Console agent
You should reach out to your NetApp Sales Rep to try out or use ONTAP alerts. Then, when you use the Console agent, it will include the appropriate capabilities for ONTAP alerts.
To create the Console agent in the NetApp Console, refer to the BlueXP documentation that describes how to create a Console agent.
After you set up the Console agent and add the system, wait about 15 minutes for the initial discovery.
