Retrieve audit options
Retrieves audit filter options for a specified account ID. Use this to view the available filters for auditing activities.
HTTP method and endpoint
GET /audit/{accountId}/options
Token usage
NetApp Console user token.
Usage notes
Retrieves filter options by a specified account ID.
accountId |
string |
path |
True |
Status: 200,
Hash mapping strings to array[AuditOptionItem]
AuditOptionItem
| Name | Type | Required | Description |
column |
string |
False |
Column name for the audit option |
identifier |
string |
False |
Unique identifier for the audit option |
label |
string |
False |
Display label for the audit option |
