Licenses and subscriptions
Terms and definitions
Contributors netapp-ahibbard netapp-revathid netapp-ml94669
Billing preferences control how NetApp Console handles payments, invoices, and renewal behavior for your licenses and subscriptions. You set preferences at one of two levels:
  • Global — applies across direct licenses, marketplace subscriptions, and Keystone subscriptions.
  • Per subscription — applies only to a specific marketplace or direct license contract.
Billing sources can be:
  • Marketplace subscriptions — Billing occurs through AWS Marketplace, Azure Marketplace, or Google Cloud Marketplace. You can choose the billing account, region, and renewal options provided by the cloud marketplace.
  • Direct licenses — Billing occurs through NetApp. You manage license keys, invoice contacts, and auto-renewal in NetApp Console.
  • Keystone subscriptions — Billing occurs through your Keystone agreement. You manage invoice recipients and cost center tags in NetApp Console.
Permissions
You need the Account Admin or Billing Admin role to change billing preferences. Operators can view preferences but cannot modify them.
Set billing preferences
Billing preferences let you:
  • enforce a single invoice contact list across services,
  • align usage to cost centers,
  • manage auto-renewal and expiry notifications,
  • ensure new Cloud Volumes ONTAP (CVO) systems inherit the correct billing account.
Billing fields
Marketplace fields
  • Marketplace provider — AWS, Azure, or Google Cloud.
  • Billing account / subscription ID — The cloud billing account to charge.
  • Contract term — Term length and renewal behavior.
Billing options and definitions
Terms and options
  • NetApp licenses first — Bills against active NetApp licenses. Additional usage moves to the marketplace.
  • Marketplace subscriptions only — All usage is billed through marketplace contracts.
  • PAYGO (Pay-As-You-Go) — Flexible subscription billed by actual usage.
  • Annual contract — Fixed-term marketplace subscription.
  • Auto renew — Renews the contract automatically at expiration.
  • Custom CVO configuration — Advanced mode for mapping multiple subscriptions per cloud provider.
  • Direct license — NetApp-managed license used before marketplace capacity.
  • Hyperscaler — AWS, Azure, or Google Cloud provider.
  • Confirm changes dialog — Appears before applying updates to prevent accidental billing changes.
Typical configuration paths
Scenario Recommended billing option
Using purchased NetApp capacity
Using marketplace contracts only
Billing multiple projects under one cloud provider
Enable Custom CVO configuration
Reverting to default billing
Disable Custom CVO configuration
