Use the dashboard overview
The Overview dashboard in the NetApp Console helps you monitor the statuses of your licenses and subscriptions to ensure that you can manage costs and maintain service as subscriptions reach expiration dates or capacity limits.
You can view specific license and subscription information about each of your data services (including Cloud Volumes ONTAP).
The Licenses and subscriptions dashboard alerts you to upcoming capacity limits or expirations, prompting you to take the requisite action.
View details about a specific data service
The Overview dashboard provides details about the following services:
Backup and Recovery
Cloud Tiering
Cloud Volumes ONTAP
Disaster Recovery
Ransomware Resilience
For example, administrators tasked with managing Cloud Volumes ONTAP resources can view the current capacity of each license or subscription, which gives them a focused view of resources within their purview.
Although you can update and remove licenses from the dashboard, you cannot add a new license or subscription. |
From the NetApp Console menu, select Administration > Licenses and subscriptions.
Select Overview.
Select View for the respective data service (including Cloud Volumes ONTAP) to view details and manage licenses and subscriptions.
Each tile provides a graphical overview of capacity. You can view the details page to see and manage payment methods for that capacity.
Select either the Licenses or Subscriptions tab.
Filter the table by selecting a column filter and a value to filter by. For example, on the Subscriptions tab, you can filter the Type column by Annual Contract or Subscription.
Customize the columns shown in the table. You can add and remove columns from the table by selecting the Column icon to indicate which columns you want to show or hide.
Expand any row to view details of what the subscription or license includes, capacity purchased, and terms.
Use the actions menu to manage a specific license or subscription, such as updating a license or associating a subscription with a different organization.
You can't add new licenses or subscriptions from the Overview page for a specific service. You can only add licenses from the Direct licenses tab or subscriptions from the Marketplace subscriptions tab.
Resolve license or subscription issues
In the Overview dashboard, you can view license and subscription issues that need to be resolved. Issues include licenses and subscriptions that are expiring or reaching capacity.
Select Overview.
In the Requires action tile, select Resolve to view issues that need to be adjusted. If Resolve does not display, there are no issues requiring action.
From the Requires action page, select either the Licenses tab or the Subscriptions tab.
Use the actions menu to resolve the issue.
