Lifecycle planning
Set reminders to check again in Lifecycle planning
Contributors amgrissino
Rather than add capacity or tier cold data, in Lifecycle planning you can choose no action required at this time and set reminders for yourself to check again after 30, 60, or 90 days.
Steps
  1. Log in to the NetApp Console.
  2. Select Evaluate Storage Options for the asset.
  3. Select No action needed.
  4. Choose when you want to be notified again of a potential low-capacity issue: 30, 60, or 90 days.
  5. Select Save.
Result
After that time elapses, the risk appears again in the list of risks.
