Delete a performance policy in NetApp Console local deployment
DELETE /v1/organizations/{organizationId}/performancepolicies/{performancePolicyId}
Deletes a performance policy by using its unique identifier within the specified organization. Delete is only allowed when:
  • no workloads are associated with the storage class.
  • storageClassType is 'USER_DEFINED'.
organizationId
string
path
True
Unique identifier of the organization.
performancePolicyId
string
path
True
Unique identifier of the performance policy that is to be deleted.
Status: 204, Performance policy deleted successfully.
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
