Delete a protection policy in NetApp Console local deployment
DELETE /v1/organizations/{organizationId}/protectionpolicies/{protectionPolicyId}
Deletes an existing protection policy. The protection policy can only be deleted if there is no workload associated with it and it is not system-defined.
organizationId
string
path
True
Organization ID
protectionPolicyId
string
path
True
Protection Policy ID
  • example: 4fa85f64-5717-4562-b3fc-2c963f66afa7
Status: 204, Protection policy deleted successfully.
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
