Delete a security policy in NetApp Console local deployment
DELETE /v1/organizations/{organizationId}/securitypolicies/{securityPolicyId}
Deletes an existing security policy. The security policy can only be deleted if there is no workload associated with it and it is not system-defined.
organizationId |
string |
path |
True |
Organization ID |
securityPolicyId |
string |
path |
True |
Security Policy ID
Status: 204, Security policy deleted successfully.
Status: 400, Bad request
| Name | Type | Required | Description |
correlationId |
string |
False |
Internal UUID representing the request or trace ID related. |
detail |
string |
False |
Details about the problem. |
invalidParams |
array[invalidParams] |
False |
List of invalid parameters. |
status |
string |
True |
HTTP error code related to the problem. |
title |
string |
True |
Title description of the problem. |
type |
string |
True |
Content-type of the object. |
Example error response
"status": "400",
"type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "401",
Status: 403, Forbidden
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "403",
"type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "404",
"type": "https://bluexp.netapp.io/problems/2"
invalidParams
name |
string |
True |
Name of the invalid parameter. |
reason |
string |
True |
Reason why the parameter is invalid. |
