Delete an existing storage class in NetApp Console local deployment
Deletes a user-defined storage class that has no associated workloads, using its unique identifier within the specified organization.
HTTP method and endpoint
DELETE /v1/organizations/{organizationId}/storageclasses/{storageClassId}
Usage notes
Deletes a storage class by using its unique identifier within the specified organization. Delete is only allowed when:
no workloads are associated with the storage class.
storageClassType is 'user-defined'.
storageClassId |
string |
path |
True |
Unique identifier of the storage class to delete. |
organizationId |
string |
path |
True |
Unique identifier of the organization. |
Status: 204, Storage class deleted successfully.
Status: 400, Bad request
| Name | Type | Required | Description |
correlationId |
string |
False |
Internal UUID representing the request or trace ID related. |
detail |
string |
False |
Details about the problem. |
invalidParams |
array[invalidParams] |
False |
List of invalid parameters. |
status |
string |
True |
HTTP error code related to the problem. |
title |
string |
True |
Title description of the problem. |
type |
string |
True |
Content-type of the object. |
Example error response
"status": "400",
"type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "401",
Status: 403, Forbidden
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "403",
"type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "404",
"type": "https://bluexp.netapp.io/problems/2"
invalidParams
name |
string |
True |
Name of the invalid parameter. |
reason |
string |
True |
Reason why the parameter is invalid. |
