Delete a system in NetApp Console local deployment
Removes the specified on-premises system from an organization in a NetApp Console local deployment.
HTTP method and endpoint
DELETE /v1/organizations/{organizationId}/workingenvironments/{workingEnvironmentId}
organizationId
string
path
True
Organization ID
  • example: 3fa85f64-5717-4562-b3fc-2c963f66afa6
string
path
True
System ID
  • example: OnPremWorkingEnvironment-3fa85f64-5717-4562-b3fc-2c963f66afa6
Status: 204, System deleted successfully. No content returned.
Status: 403, Forbidden request
  "detail": "You do not have permission to delete this system.",
  "status": "403",
  "title": "Forbidden",
  "type": "https://bluexp.netapp.io/problems/403"
Status: 404, Not found
  "detail": "The specified system does not exist.",
  "status": "404",
  "title": "Not Found",
  "type": "https://bluexp.netapp.io/problems/404"
Status: 401, Unauthorized access
Example error response
  "detail": "Authentication required or invalid credentials.",
  "status": "401",
  "title": "Unauthorized",
  "type": "https://bluexp.netapp.io/problems/401"
