Retrieve protection policy details in NetApp Console local deployment
GET /v1/organizations/{organizationId}/protectionpolicies/{protectionPolicyId}
Retrieves the details of the specified protection policy.
organizationId
string
path
True
Organization ID
protectionPolicyId
string
path
True
Protection Policy ID
  • example: 4fa85f64-5717-4562-b3fc-2c963f66afa7
Status: 200, Successfully retrieved protection policy details.
description
string
False
Description of the protection policy.
id
string
True
Unique identifier of the protection policy.
metadata
type_bxp_metadata
False
Metadata associated with the resource.
name
string
True
Name of the protection policy.
organizationId
string
False
Organization ID that the policy is associated with.
policyType
string
False
Type of the protection policy.
snapshotSchedules
array[snapshotSchedules]
False
An array of snapshot schedules defined in the protection policy.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the protection policy. Can be used to add any additional data related to the protection policy.
type
string
False
  • "application/vnd.netapp.bxp.protectionpolicy"
version
string
False
Version of the resource schema. Defined values are:
  • "1.0"
  "description": "Daily snapshot policy with 7 day retention",
  "id": "4fa85f64-5717-4562-b3fc-2c963f66afa7",
  "metadata": {
    "createdBy": "666a3f38-d4fa-5b62-a391-a69029758d32",
    "labels": [],
    "modifiedBy": "666a3f38-d4fa-5b62-a391-a69029758d32"
  "name": "Daily Backup Policy",
  "organizationId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "policyType": "USER_DEFINED",
  "snapshotSchedules": [
      "retentionCount": 7,
      "schedule": "DAILY"
      "retentionCount": 4,
      "schedule": "WEEKLY"
  "tags": [
      "internal:bxp:metric:associatedWorkloadCnt": "2"
  "type": "application/vnd.netapp.bxp.protectionpolicy",
  "version": "1.0"
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
type_bxp_label
Name/value pair.
name
string
True
Name of the label.
value
string
True
Value of the label.
type_bxp_metadata
createdBy
string
False
UUID of the user who created the resource.
creationTimestamp
string
False
Resource creation date.
labels
array[type_bxp_label]
False
Array of name/value pairs representing additional information for the resource.
string
False
Resource modification date.
modifiedBy
string
False
UUID of the user who modified the resource.
snapshotSchedules
retentionCount
integer
False
Number of snapshots to retain.
schedule
string
False
Type of schedule for snapshots.
tags Hash mapping strings to string
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
