Update a capacity policy in NetApp Console local deployment
PATCH /v1/organizations/{organizationId}/capacitypolicies/{capacityPolicyId}
Updates the specified capacity policy.
organizationId |
string |
path |
True |
Organization ID
capacityPolicyId |
string |
path |
True |
Capacity policy ID
Request Body
Capacity policy properties to update. Only include the fields you want to modify.
| Name | Type | Required | Description |
autoGrow |
string |
False |
Auto-grow setting of the capacity policy. |
description |
string |
False |
Description of the capacity policy. |
name |
string |
False |
Name of the capacity policy. |
spaceReserved |
string |
False |
Space reservation setting of the capacity policy. |
tags |
array[tags] |
False |
JSON array of tags (name/value pairs) associated with the capacity policy. |
tiering |
string |
False |
Tiering setting of the capacity policy. |
type |
string |
True |
version |
string |
True |
Version of the resource schema. Defined values are:
volumeType |
string |
False |
Volume type setting of the capacity policy. |
Example request
"autoGrow": "GROW_SHRINK",
"description": "Updated policy with new tiering configuration",
"name": "Updated Production Policy",
"spaceReserved": "THICK",
"tags": [
"internal:bxp:metric:associatedWorkloadCnt": "2"
"internal:bxp:metric:complianceStatus": "compliant"
"tiering": "SNAPSHOT_ONLY",
"type": "application/vnd.netapp.bxp.capacitypolicy",
"version": "1.0",
"volumeType": "FLEXGROUP"
Status: 204, Capacity policy updated successfully
Status: 400, Bad request
correlationId |
string |
False |
Internal UUID representing the request or trace ID related. |
detail |
string |
False |
Details about the problem. |
invalidParams |
array[invalidParams] |
False |
List of invalid parameters. |
status |
string |
True |
HTTP error code related to the problem. |
title |
string |
True |
Title description of the problem. |
type |
string |
True |
Content-type of the object. |
Example error response
"status": "400",
"type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "401",
Status: 403, Forbidden
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "403",
"type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "404",
"type": "https://bluexp.netapp.io/problems/2"
Status: 409, Conflict
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "409",
"type": "https://bluexp.netapp.io/problems/10"
invalidParams
name |
string |
True |
Name of the invalid parameter. |
reason |
string |
True |
Reason why the parameter is invalid. |
