Update an existing performance policy in NetApp Console local deployment
Updates an existing performance policy using its unique identifier within the specified organization.
HTTP method and endpoint
PATCH /v1/organizations/{organizationId}/performancepolicies/{performancePolicyId}
Usage notes
Updates an existing performance policy by using its unique identifier within the specified organization.
organizationId
string
path
True
Unique identifier of the organization.
performancePolicyId
string
path
True
Unique identifier of the performance policy to be updated.
Request Body
Expected to contain parameters for updating the performance policy.
adaptive
adaptive_performance_policy_1.0_patch_request_body
False
Adaptive performance policy details.
description
string
False
Description of the performance policy.
name
string
False
Name of the performance policy.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the performance policy. Can be used to add any additional data related to the performance policy.
type
string
True
  • "application/vnd.netapp.bxp.performancepolicy"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "adaptive": {
    "absoluteMinIopsPerTb": 900,
    "expectedIopsPerTb": 1200,
    "expectedLatency": 400,
    "peakIopsPerTb": 1800
  "description": "Updated configuration for performance workloads",
  "name": "Updated Performance Policy",
  "tags": [
      "internal:bxp:metric:associatedWorkloadCnt": "5"
  "type": "application/vnd.netapp.bxp.performancepolicy",
  "version": "1.0"
Status: 204, Performance policy updated successfully.
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
Status: 409, Conflict
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "409",
  "type": "https://bluexp.netapp.io/problems/10"
integer
False
Absolute minimum IOPS per terabyte that is used as an override when the expected IOPS is less than this value.
expectedIopsPerTb
integer
False
Minimum expected IOPS, per terabyte.
expectedLatency
integer
False
Expected latency, in milliseconds.
peakIopsPerTb
integer
False
Maximum expected IOPS, per terabyte.
tags Hash mapping strings to string
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
