Update a protection policy in NetApp Console local deployment
PATCH /v1/organizations/{organizationId}/protectionpolicies/{protectionPolicyId}
Modifies an existing protection policy. Include only the fields you want to update in the request. The protection policy can only be modified if there is no workload associated with it and it is not system-defined.
organizationId
string
path
True
Organization ID
protectionPolicyId
string
path
True
Protection policy ID
  • example: 4fa85f64-5717-4562-b3fc-2c963f66afa7
Request Body
description
string
False
Protection policy description.
name
string
False
Protection policy name.
snapshotSchedules
array[snapshotSchedules]
False
Array of snapshot schedule objects used to create local snapshot policies.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the performance policy. Can be used to add any additional data related to the performance policy.
type
string
True
  • "application/vnd.netapp.bxp.protectionpolicy"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "name": "New Policy Name",
  "snapshotSchedules": [
      "retentionCount": 48,
      "schedule": "HOURLY"
      "retentionCount": 7,
      "schedule": "DAILY"
Status: 204, Protection policy updated successfully.
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
Status: 409, Conflict
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "409",
  "type": "https://bluexp.netapp.io/problems/10"
snapshotSchedules
retentionCount
integer
True
Number of snapshots to be retained for a schedule.
schedule
string
True
Snapshot schedule frequency.
tags Hash mapping strings to string
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
