Update a security policy in NetApp Console local deployment
Modifies an existing security policy that has no associated workloads and is not system-defined.
HTTP method and endpoint
PATCH /v1/organizations/{organizationId}/securitypolicies/{securityPolicyId}
Usage notes
Include only the fields you want to update in the request. The security policy can only be modified if there is no workload associated with it and if it is not system-defined.
organizationId
string
path
True
Organization ID
securityPolicyId
string
path
True
Security Policy ID
  • example: 5fa85f64-5717-4562-b3fc-2c963f66afa8
Request Body
description
string
False
Security policy description.
encryptionType
string
False
Encryption type setting. Should be enabled (ENABLED) or can be enabled or disabled (ANY).
fips
string
False
FIPS setting. Should be enabled (ON), disabled (OFF), or can be enabled or disabled (ANY).
name
string
False
Security policy name.
ransomwareProtection
string
False
Ransomware protection setting. Should be enabled (ON), disabled (OFF), or can be enabled or disabled (ANY).
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the performance policy. Can be used to add any additional data related to the performance policy.
type
string
True
  • "application/vnd.netapp.bxp.securitypolicy"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "description": "Updated security policy for production workloads",
  "encryptionType": "ENABLED",
  "fips": "OFF",
  "name": "Updated High Security Policy",
  "ransomwareProtection": "OFF",
  "tags": [
      "internal:bxp:metric:complianceStatus": "compliant"
  "type": "application/vnd.netapp.bxp.securitypolicy",
  "version": "1.0"
Status: 204, Security policy updated successfully.
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
Status: 409, Conflict
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "409",
  "type": "https://bluexp.netapp.io/problems/10"
tags Hash mapping strings to string
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
