Discover and register a storage device as a system in NetApp Console local deployment
Discovers and registers a storage device as a system in the specified organization and fleet. Supports validation without registration.
HTTP method and endpoint
POST /v1/organizations/{organizationId}/fleets/{fleetId}/workingenvironments
Usage notes
Use stateDesired to control the behavior:
VALIDATED: Only validates the storage device without registration. Returns 204 with no content.
REGISTERED: Validates and registers the storage device. Returns 201 with system details.
organizationId |
string |
path |
True |
Organization ID
fleetId |
string |
path |
True |
Fleet ID
Request Body
| Name | Type | Required | Description |
fleetId |
string |
False |
Optional Fleet ID to associate with the discovered storage device. |
ip |
string |
True |
Storage device IP from user input. |
password |
string |
True |
Storage device password. |
stateDesired |
string |
True |
Desired state for the system. VALIDATED only validates the storage device without registering. REGISTERED validates and registers the storage device. |
type |
string |
False |
Type of the system. |
username |
string |
True |
Storage device username. |
Example request
"ip": "10.193.96.173",
"password": "password123",
"stateDesired": "REGISTERED",
"type": "ON_PREM",
"username": "admin"
Status: 201, System discovered and registered successfully (when stateDesired is REGISTERED).
aff |
boolean |
True |
Indicates whether the system is AFF (All Flash FAS). |
id |
string |
False |
Unique identifier for the system. |
name |
string |
True |
Name of the system. |
type |
string |
True |
Location type of the cluster. |
workingEnvironmentId |
string |
True |
Unique identifier for the discovered system, which might differ from the internal ID used by the system. This is the ID that will be used in API calls to reference this system. |
"aff": false,
"id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
"name": "onprem-cluster-01",
"type": "ON_PREM",
"workingEnvironmentId": "OnPremWorkingEnvironment-3fa85f64-5717-4562-b3fc-2c963f66afa6"
Status: 204, Cluster validated successfully. no content returned (when statedesired is validated).
Status: 401, Unauthorized access
"detail": "Invalid or missing bearer token",
"status": "401",
"title": "Unauthorized",
"type": "https://bluexp.netapp.io/problems/401"
Status: 403, Forbidden request
"detail": "Request forbidden. Insufficient permissions.",
"status": "403",
"title": "Forbidden",
"type": "https://bluexp.netapp.io/problems/403"
Status: 400, Bad request
Example error response
"detail": "Timeout reached while trying to connect to cluster at 10.10.10.100",
"status": "400",
"title": "Connection Timeout",
"type": "https://bluexp.netapp.io/problems/400"
