Create a new performance policy in NetApp Console local deployment
POST /v1/organizations/{organizationId}/performancepolicies
Creates a new performance policy within the specified organization.
organizationId
string
path
True
Unique identifier of the organization.
Request Body
Expected to contain necessary parameters for creating a new performance policy.
adaptive
adaptive_perf_policy_1.0
True
Adaptive performance policy details.
description
string
False
Description of the performance policy.
name
string
True
Name of the performance policy.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the performance policy. Can be used to add any additional data related to the performance policy.
type
string
True
  • "application/vnd.netapp.bxp.performancepolicy"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "adaptive": {
    "absoluteMinIopsPerTb": 1500,
    "expectedIopsPerTb": 2000,
    "expectedLatency": 200,
    "peakIopsPerTb": 3000
  "description": "Configuration for extreme performance on workloads",
  "name": "Extreme Performance",
  "tags": [
      "internal:bxp:metric:associatedWorkloadCnt": "3"
  "type": "application/vnd.netapp.bxp.performancepolicy",
  "version": "1.0"
Status: 201, Performance policy created successfully
adaptive
False
description
string
False
id
string
True
Unique identifier of the performance policy.
metadata
type_bxp_metadata
False
Metadata associated with the resource.
name
string
True
organizationId
string
False
Organization ID that the policy is associated with.
policyType
string
False
Type of the performance policy.
tags
array[tags]
False
type
string
False
version
string
False
  • "1.0"
  "adaptive": {
    "absoluteMinIopsPerTb": 800,
    "expectedIopsPerTb": 1000,
    "expectedLatency": 500,
    "peakIopsPerTb": 1500
  "description": "Configuration for high performance workloads",
  "id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "metadata": {
    "createdBy": "666a3f38-d4fa-5b62-a391-a69029758d32",
    "labels": [],
    "modifiedBy": "666a3f38-d4fa-5b62-a391-a69029758d32"
  "name": "High Performance Policy",
  "organizationId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "policyType": "USER_DEFINED",
  "tags": [
      "internal:bxp:metric:associatedWorkloadCnt": "2"
  "version": "1.0"
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
Status: 409, Conflict
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "409",
  "type": "https://bluexp.netapp.io/problems/10"
integer
False
Absolute minimum IOPS per terabyte that is used as an override when the expected IOPS is less than this value.
expectedIopsPerTb
integer
True
Minimum expected IOPS, per terabyte.
expectedLatency
integer
True
Expected latency, in milliseconds.
peakIopsPerTb
integer
True
Maximum expected IOPS, per terabyte.
tags Hash mapping strings to string
type_bxp_label
Name/value pair.
name
string
True
Name of the label.
value
string
True
Value of the label.
type_bxp_metadata
createdBy
string
False
UUID of the user who created the resource.
creationTimestamp
string
False
Resource creation date.
labels
array[type_bxp_label]
False
Array of name/value pairs representing additional information for the resource.
string
False
Resource modification date.
modifiedBy
string
False
UUID of the user who modified the resource.
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
