Create a new storage class in NetApp Console local deployment
Creates a new storage class within the specified organization.
HTTP method and endpoint
POST /v1/organizations/{organizationId}/storageclasses
organizationId
string
path
True
Unique identifier of the organization.
Request Body
Expected to contain necessary parameters for creating a new storage class. At least one policy must be present in the request to create a storage class.
capacityPolicy
string
False
Capacity policy ID associated with the storage class.
description
string
False
Description of the storage class.
name
string
True
Name of the storage class. This name must be unique within the specific organization.
performancePolicy
string
False
Performance policy ID associated with the storage class.
protectionPolicies
array[string]
False
List of protection policies associated with the storage class.
securityPolicy
string
False
Security policy ID associated with the storage class.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the storage class. Can be used to add any additional data related to the storage class.
type
string
True
  • "application/vnd.netapp.bxp.storageclass"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "capacityPolicy": "b336b8c1-b388-43e4-8f85-4ca84121ebda",
  "description": "Configuration for high performance workloads",
  "name": "High Performance Configuration",
  "performancePolicy": "494a3e48-812a-4204-8450-32aa6aaf1c5f",
  "protectionPolicies": [
    "92a8fc02-3bd2-4e1f-b034-521ca42ddabf"
  "securityPolicy": "188714a5-6687-4410-83c3-7214f2943b2d",
  "tags": [
      "internal:bxp:metric:associatedWorkloadCnt": "3"
  "type": "application/vnd.netapp.bxp.storageclass",
  "version": "1.0"
Status: 201, Storage class created successfully.
capacityPolicy
capacity_policy_1.0_get_response_body
False
description
string
False
id
string
False
Unique identifier of the storage class.
metadata
type_bxp_metadata
False
Metadata associated with the resource.
name
string
False
organizationId
string
False
Organization ID that the storage class is associated with.
performancePolicy
performance_policy_1.0_get_response_body
False
protectionPolicies
array[protection_policy_1.0_get_response_body]
False
securityPolicy
security_policy_1.0_get_response_body
False
storageClassType
string
False
Type of the storage class.
tags
array[tags]
False
type
string
False
version
string
False
  • "1.0"
  "capacityPolicy": {
    "id": "b336b8c1-b388-43e4-8f85-4ca84121ebda",
    "name": "General Purpose Capacity Policy"
  "id": "0fedcba9-8765-4321-0fed-cba987654321",
  "metadata": {
    "createdBy": "666a3f38-d4fa-5b62-a391-a69029758d32",
    "labels": [],
    "modifiedBy": "666a3f38-d4fa-5b62-a391-a69029758d32"
  "organizationId": "123e4567-e89b-12d3-a456-426614174000",
  "performancePolicy": {
    "id": "494a3e48-812a-4204-8450-32aa6aaf1c5f",
    "name": "High Performance Policy"
      "id": "92a8fc02-3bd2-4e1f-b034-521ca42ddabf",
      "name": "Snapshot Protected Policy"
  "securityPolicy": {
    "id": "188714a5-6687-4410-83c3-7214f2943b2d",
    "name": "Encryption Enabled Policy"
  "storageClassType": "SYSTEM_DEFINED",
  "tags": [
      "internal:bxp:metric:complianceStatus": "compliant"
  "version": "1.0"
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
Status: 409, Conflict
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "409",
  "type": "https://bluexp.netapp.io/problems/10"
tags Hash mapping strings to string
type_bxp_label
Name/value pair.
name
string
True
Name of the label.
value
string
True
Value of the label.
type_bxp_metadata
createdBy
string
False
UUID of the user who created the resource.
creationTimestamp
string
False
Resource creation date.
labels
array[type_bxp_label]
False
Array of name/value pairs representing additional information for the resource.
string
False
Resource modification date.
modifiedBy
string
False
UUID of the user who modified the resource.
autoGrow
string
False
Auto-grow setting of the capacity policy.
description
string
False
Description of the capacity policy.
id
string
True
Unique identifier of the capacity policy.
metadata
type_bxp_metadata
False
name
string
True
Name of the capacity policy.
organizationId
string
False
Organization ID that the policy is associated with.
policyType
string
False
Type of the capacity policy.
spaceReserved
string
False
Space reservation setting of the capacity policy.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the capacity policy. Can be used to add any additional data related to the capacity policy.
tiering
string
False
Tiering setting of the capacity policy.
type
string
False
  • "application/vnd.netapp.bxp.capacitypolicy"
version
string
False
  • "1.0"
volumeType
string
False
Volume type setting of the capacity policy.
adaptive_perf_policy_1.0
Adaptive performance policy details.
absoluteMinIopsPerTb
integer
False
Absolute minimum IOPS per terabyte that is used as an override when the expected IOPS is less than this value.
expectedIopsPerTb
integer
True
Minimum expected IOPS, per terabyte.
expectedLatency
integer
True
Expected latency, in milliseconds.
peakIopsPerTb
integer
True
Maximum expected IOPS, per terabyte.
adaptive
False
description
string
False
Description of the performance policy.
id
string
True
Unique identifier of the performance policy.
metadata
type_bxp_metadata
False
name
string
True
Name of the performance policy.
organizationId
string
False
policyType
string
False
Type of the performance policy.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the performance policy. Can be used to add any additional data related to the performance policy.
type
string
False
  • "application/vnd.netapp.bxp.performancepolicy"
version
string
False
  • "1.0"
snapshotSchedules
retentionCount
integer
False
Number of snapshots to retain.
schedule
string
False
Type of schedule for snapshots.
description
string
False
Description of the protection policy.
id
string
True
Unique identifier of the protection policy.
metadata
type_bxp_metadata
False
name
string
True
Name of the protection policy.
organizationId
string
False
policyType
string
False
Type of the protection policy.
snapshotSchedules
array[snapshotSchedules]
False
An array of snapshot schedules defined in the protection policy.
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the protection policy. Can be used to add any additional data related to the protection policy.
type
string
False
  • "application/vnd.netapp.bxp.protectionpolicy"
version
string
False
  • "1.0"
description
string
False
Description of the security policy.
encryptionType
string
False
Type of encryption applied by the security policy. Should be enabled (ENABLED) or can be enabled or disabled (ANY).
fips
string
False
FIPS setting. Should be enabled (ON), disabled (OFF), or can be enabled or disabled (ANY).
id
string
True
Unique identifier of the security policy.
metadata
type_bxp_metadata
False
name
string
True
Name of the security policy.
organizationId
string
False
policyType
string
False
Type of the security policy.
ransomwareProtection
string
False
Ransomware protection setting. Should be enabled (ON), disabled (OFF), or can be enabled or disabled (ANY).
tags
array[tags]
False
JSON array of tags (name/value pairs) associated with the security policy. Can be used to add any additional data related to the security policy.
type
string
False
  • "application/vnd.netapp.bxp.securitypolicy"
version
string
False
  • "1.0"
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
