Retrieve system recommendations for storage placement in NetApp Console local deployment
Retrieves system recommendations for storage placement in a NetApp Console local deployment. Calculates cluster and SVM storage in the fleet based on constraints and storage classes.
HTTP method and endpoint
POST /v1/organizations/{organizationId}/systemrecommendations
Usage notes
Calculates the cluster and SVM storage in the fleet to make recommendations based on the constraints and storage classes. Returns a list of system recommendations for optimal storage placement.
Note Returns three recommendations by default.
organizationId
string
path
True
Organization ID
Request Body
System recommendations request payload
capacityPolicyId
string
False
Optional capacity policy identifier for the recommendation.
fleetId
string
False
Fleet identifier for the recommendation.
performancePolicyId
string
False
Optional performance policy identifier for the recommendation.
securityPolicyId
string
False
Optional security policy identifier for the recommendation.
size
integer
True
Size of the storage, in bytes.
storageClassId
string
False
Optional storage class identifier for the recommendation.
storageCount
integer
False
Number of storage units requested, used to specify LUN count.
storageType
string
True
Type of storage requested.
type
string
True
  • "application/vnd.netapp.bxp.systemrecommendations"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "fleetId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "size": 107374182400,
  "storageClassId": "888c5g50-f6gc-7d84-c5b3-c89241970f54",
  "storageCount": 4,
  "storageType": "LUN",
  "type": "application/vnd.netapp.bxp.systemrecommendations",
  "version": 1
Status: 200, Successful response with system recommendations
count
integer
False
Number of recommendations provided
items
array[items]
False
List of placement recommendations.
  • example: [{"availableCapacity" => 549755813888, "fleets" => [{"id" => "666a3f38-d4fa-5b62-a391-a69029758d31", "name" => "fleet-name-1"}], "name" => "cluster-name-1", "ontapVersion" => "9.16.1", "personality" => "UNIFIED_ONTAP", "recommendation" => "STRICT", "svms" => [{"aggregates" => [{"id" => "aaa17i72-h8ie-9f06-e7d5-ea145392h76", "name" => "aggr1", "recommendation" => "STRICT"}, {"id" => "bbb28j83-i9jk-0l17-f8g6-faa65243h81", "name" => "dataAggr2", "recommendation" => "RELAXED"}], "enabledProtocols" => ["NFS", "CIFS"], "id" => "777b4f49-e5fb-6c73-b4a2-b79130869e43", "name" => "svm1", "recommendation" => "STRICT"}, {"aggregates" => [{"id" => "bbb28j83-i9jk-0l17-f8g6-faa65243h81", "name" => "dataAggr2", "recommendation" => "RELAXED"}], "enabledProtocols" => ["iSCSI"], "id" => "888c5g50-f6gc-7d84-c5b3-c89241970f54", "name" => "svm2", "recommendation" => "RELAXED"}], "totalCapacity" => 1099511627776, "usedCapacity" => 536870912000, "workingEnvironmentId" => "OnPremWorkingEnvironment-RRpEXDdH"}, {"availableCapacity" => 1099511627776, "fleets" => [{"id" => "999d6h61-g7hd-8e95-d6c4-d99352081g65", "name" => "fleet-name-2"}], "name" => "cluster-name-2", "ontapVersion" => "9.12.1", "personality" => "ASA_R2", "recommendation" => "RELAXED", "svms" => [{"aggregates" => [{"id" => "bbb28j83-i9jk-0l17-f8g6-faa65243h81", "name" => "dataAggr2", "recommendation" => "RELAXED"}], "enabledProtocols" => ["NFS"], "id" => "aaa17i72-h8ie-9f06-e7d5-ea145392h76", "name" => "svm3", "recommendation" => "RELAXED"}], "totalCapacity" => 2199023255552, "usedCapacity" => 536870911900, "workingEnvironmentId" => "OnPremWorkingEnvironment-XYZ789"}]
  "count": 1,
  "items": [
      "availableCapacity": 536870912000,
      "name": "onprem-cluster-01",
      "ontapVersion": "9.16.1",
      "personality": "UNIFIED_ONTAP",
      "recommendation": "STRICT",
      "svms": [
          "aggregates": [
              "id": "bbb28j83-i9jk-0l17-f8g6-faa65243h81",
              "name": "dataAggr",
          "enabledProtocols": [
            "NFS",
            "CIFS"
          "id": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
          "name": "svm1",
          "aggregates": [
              "name": "dataAggr",
              "id": "ccc39k94-j0kl-1m28-g9h7-gbb76354i92",
              "name": "dataAggr2",
              "recommendation": "RELAXED"
            "NFS"
          "id": "4fb96g75-6828-5673-c4gd-3d074g77bgb7",
          "name": "svm2",
      "totalCapacity": 1073741824000,
      "usedCapacity": 536870912000,
      "version": 1,
      "workingEnvironmentId": "OnPremWorkingEnvironment-abc123xyz"
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
aggregates
id
string
False
Aggregate identifier
name
string
False
Aggregate name
recommendation
string
False
Indicates whether the performance policy is followed or relaxed while recommending this aggregate. Defined values are:
  • "STRICT" - performance policy criteria is strictly followed while recommending this aggregate.
  • "RELAXED" - performance policy criteria is relaxed while recommending this aggregate.
svms
aggregates
array[aggregates]
False
List of aggregates in the SVM.
enabledProtocols
array[string]
True
List of enabled protocols on the SVM.
id
string
True
Recommended Storage Virtual Machine identifier.
name
string
True
Storage Virtual Machine name.
recommendation
string
False
Indicates whether the performance policy is followed or relaxed while recommending this Storage VM. If any aggregate under this SVM is recommended with a strict policy, the SVM recommendation will also be strict. Defined values are:
  • "STRICT" - performance policy criteria is strictly followed while recommending this SVM.
  • "RELAXED" - performance policy criteria is relaxed while recommending this SVM.
items
availableCapacity
integer
True
Available capacity of the system, in bytes.
name
string
True
Recommended cluster name.
ontapVersion
string
False
ONTAP version of the system.
  • example: 9.16.1
personality
string
False
The personality of the ONTAP cluster. Defined values are:
  • "UNIFIED_ONTAP" - A traditional unified ONTAP cluster (not disaggregated).
  • "ASA_R2" - A disaggregated, SAN-optimized All-Flash SAN Array (ASA) r2 cluster.
  • "AFX" - A disaggregated cluster that is not SAN-optimized.
  • enum: ["UNIFIED_ONTAP", "ASA_R2", "AFX"]
  • example: UNIFIED_ONTAP
recommendation
string
False
Indicates whether the performance policy is followed or relaxed while recommending this cluster. If any SVM under this cluster is recommended with a strict policy, the cluster recommendation will also be strict. Defined values are:
  • "STRICT" - performance policy criteria is strictly followed while recommending this cluster.
  • "RELAXED" - performance policy criteria is relaxed while recommending this cluster.
svms
array[svms]
True
List of Storage Virtual Machines in the system.
totalCapacity
integer
True
Total capacity of the system, in bytes.
type
string
True
usedCapacity
integer
False
Used capacity of the system, in bytes.
version
string
True
  • "1.0"
string
True
Recommended system identifier.
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
