Create a new LUN in NetApp Console local deployment
Creates a new LUN in the specified system.
HTTP method and endpoint
POST /v1/organizations/{organizationId}/workingenvironments/{workingEnvironmentId}/luns
organizationId
string
path
True
Organization ID
string
path
True
Public ID of the system
Request Body
LUN properties for creation
aggregates
array[string]
False
List of aggregate identifiers where the LUN can be created.
igroups
luns_1.0_igroups
False
Igroup details for LUN access.
name
string
True
Name of the LUN that is to be provisioned.
numberOfLuns
integer
True
Number of LUNs to create.
size
integer
True
Size of the LUN, in bytes.
storageClassId
string
False
Storage class identifier.
svmId
string
True
Storage Virtual Machine identifier.
type
string
True
  • "application/vnd.netapp.bxp.lun"
version
string
True
Version of the resource schema. Defined values are:
  • "1.0"
Example request
  "aggregates": [
    "999d6h61-g7hd-8e95-d6c4-d99352081g65",
    "aaa17i72-h8ie-9f06-e7d5-ea145392h76"
  "igroups": {
    "format": "LINUX",
    "hostOs": "LINUX",
    "initiators": [
        "comment": "This is an initiator for the finance department",
        "name": "iqn.1993-08.org.debian:01:abcd1234"
        "comment": "This is an initiator for the HR department",
        "name": "iqn.1993-08.org.debian:01:efgh5678"
    "name": "my_igroup"
  "name": "my_lun",
  "numberOfLuns": 4,
  "size": 107374182400,
  "storageClassId": "888c5g50-f6gc-7d84-c5b3-c89241970f54",
  "svmId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
  "type": "application/vnd.netapp.bxp.lun",
  "version": 1
Status: 202, LUN create request accepted and is being processed
jobId
string
True
Unique identifier for the created job.
  "jobId": "3fa85f64-5717-4562-b3fc-2c963f66afa6"
Status: 400, Bad request
correlationId
string
False
Internal UUID representing the request or trace ID related.
detail
string
False
Details about the problem.
invalidParams
array[invalidParams]
False
List of invalid parameters.
status
string
True
HTTP error code related to the problem.
title
string
True
Title description of the problem.
type
string
True
Content-type of the object.
Example error response
  "status": "400",
  "type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "401",
Status: 403, Forbidden
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "403",
  "type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId
string
False
detail
string
False
invalidParams
False
status
string
True
title
string
True
type
string
True
  "status": "404",
  "type": "https://bluexp.netapp.io/problems/2"
initiators
comment
string
False
Optional comment about the initiator.
name
string
False
The WWPN, IQN, or alias of the initiator.
luns_1.0_igroups
format
string
False
LUN format
hostOs
string
False
Operating system of the host.
initiatorGroups
array[string]
False
List of initiator groups for creating a new nested group.
initiators
array[initiators]
False
List of initiators associated with the igroup.
name
string
False
Name of the igroup. To associate an existing igroup, the field is mandatory. For new igroup creation it is optional, if not provided it will default to the volume name.
invalidParams
name
string
True
Name of the invalid parameter.
reason
string
True
Reason why the parameter is invalid.
