Create a new volume in NetApp Console local deployment
POST /v1/organizations/{organizationId}/workingenvironments/{workingEnvironmentId}/volumes
Creates a new volume in the specified system.
organizationId |
string |
path |
True |
Organization ID |
workingEnvironmentId |
string |
path |
True |
Public ID of the system |
Request Body
Volume properties for creation
| Name | Type | Required | Description |
aggregates |
array[string] |
False |
List of aggregate identifiers where the volume can be created. |
cifsShares |
False |
CIFS share details. |
exportPolicy |
False |
Export policy details |
name |
string |
True |
Name of the volume to be provisioned. |
size |
integer |
True |
Size of the volume, in bytes. |
storageClassId |
string |
False |
Storage class identifier. |
svmId |
string |
True |
Storage Virtual Machine identifier. |
type |
string |
True |
version |
string |
True |
Version of the resource schema. Defined values are:
Example request
"aggregates": [
"999d6h61-g7hd-8e95-d6c4-d99352081g65",
"aaa17i72-h8ie-9f06-e7d5-ea145392h76"
"exportPolicy": {
"hosts": [
"host1",
"host2"
"name": "custom-policy"
"name": "my_volume",
"size": 107374182400,
"storageClassId": "888c5g50-f6gc-7d84-c5b3-c89241970f54",
"svmId": "3fa85f64-5717-4562-b3fc-2c963f66afa6",
"type": "application/vnd.netapp.bxp.volume",
"version": 1
Status: 202, Volume create request accepted and is being processed
jobId |
string |
True |
Unique identifier for the created job. |
"jobId": "3fa85f64-5717-4562-b3fc-2c963f66afa6"
Status: 400, Bad request
correlationId |
string |
False |
Internal UUID representing the request or trace ID related. |
detail |
string |
False |
Details about the problem. |
invalidParams |
array[invalidParams] |
False |
List of invalid parameters. |
status |
string |
True |
HTTP error code related to the problem. |
title |
string |
True |
Title description of the problem. |
type |
string |
True |
Content-type of the object. |
Example error response
"status": "400",
"type": "https://bluexp.netapp.io/problems/1"
Status: 401, Unauthorized
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "401",
Status: 403, Forbidden
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "403",
"type": "https://bluexp.netapp.io/problems/11"
Status: 404, Not found
correlationId |
string |
False |
detail |
string |
False |
invalidParams |
False |
status |
string |
True |
title |
string |
True |
type |
string |
True |
"status": "404",
"type": "https://bluexp.netapp.io/problems/2"
CIFS share details.
name |
string |
False |
Name of the CIFS share. |
permission |
string |
False |
Permissions for the CIFS share. |
usersOrGroups |
array[string] |
False |
List of users or groups with access to the CIFS share. |
volumes_1.0_export_policy
hosts |
array[string] |
False |
List of hosts associated with the export policy. |
name |
string |
False |
Name of the export policy. To associate an existing policy, name is mandatory. For new policy creation it is optional, if not provided it will default to the volume name. |
invalidParams
name |
string |
True |
Name of the invalid parameter. |
reason |
string |
True |
Reason why the parameter is invalid. |
