NetApp Console local deployment
Understanding storage class policies in NetApp Console local deployment
Contributors netapp-tonias netapp-ml94669
Storage class policies are the building blocks you use to construct a storage class. Each policy controls a specific aspect of storage behavior. When you combine policies into a storage class, you create a reusable template that the NetApp Console local deployment enforces automatically at provisioning time and monitors continuously throughout a workload's lifecycle.
Policies as building blocks
A storage class is composed of one or more policies, each governing a different dimension of storage behavior. Storage administrators define policies to encode enterprise standards—performance expectations, capacity thresholds, data placement rules—and then assemble those policies into storage class templates. When a workload is provisioned using a storage class, it inherits all of the policies in that class. This design separates the responsibility of defining standards from the act of provisioning, so storage can be provisioned consistently by automated workflows without needing to make individual configuration decisions.
Types of storage class policies
NetApp Console local deployment includes four types of policies that you can use to construct storage classes:
Performance policy
A performance policy sets expected IOPS/TB, peak IOPS/TB, absolute minimum IOPS, and expected latency targets for a workload. The Console local deployment uses these values to recommend clusters with sufficient headroom at provisioning time and to detect IOPS or latency drift after provisioning.
Capacity policy
A capacity policy controls how a volume consumes and manages space. It sets space reservation (thick, thin, or system default), autogrow behavior, FabricPool tiering, and whether to provision NAS workloads as FlexVol or FlexGroup volumes.
Security policy
A security policy sets the encryption, ransomware protection, and FIPS requirements for a workload. Each attribute can be set to a required value or left as "any" to accept the system default.
Data protection policy
A data protection policy sets the number of snapshots retained at each interval to ensure workloads using the policy get a consistent backup schedule.
Default policies
The Console local deployment includes system-defined policies across all four policy types. You can use these policies as-is when you create a storage class, or copy them as a starting point for custom policies tailored to your organization's requirements.
Performance policies
Name Type Expected IOPS/TB Peak IOPS/TB Absolute min IOPS Expected latency (ms) Summary
Extreme for Database Data
System defined
12,288
24,576
2,000
1
Use for transactional database data volumes requiring sustained high IOPS and sub-millisecond latency.
Extreme for Database Logs
System defined
22,528
45,056
4,000
1
Use for database transaction log volumes requiring the highest IOPS floor to prevent write bottlenecks.
Extreme for Database Shared Data
System defined
16,384
32,768
2,000
1
Use for shared database volumes accessed by multiple hosts requiring high throughput and consistent latency.
Extreme Performance
System defined
6,144
12,288
1,000
1
Use for HPC, AI/ML, and analytics workloads requiring high burst IOPS and predictable low latency.
Performance
System defined
2,048
4,096
500
2
Use for virtualized and enterprise applications requiring reliable performance without extreme IOPS demands.
Value
System defined
128
512
75
17
Use for cost-sensitive workloads such as home directories, file shares, and archives.
Capacity policies
Name Type Space reserve Autogrow mode Tiering policy Volume type (NAS) Summary
default
System defined
System default
System default
none
System default
Use for general workloads where platform default capacity behavior is acceptable.
production
System defined
System default
grow
none
System default
Use for production workloads that must expand automatically to prevent out-of-space failures.
Security policies
Name Type Encryption Ransomware protection FIPS Summary
default
System defined
any
any
any
Use for workloads where platform default security behavior is acceptable.
anti-ransomware
System defined
any
on
any
Use for workloads containing sensitive or business-critical data that require active ransomware protection.
production
System defined
enabled
any
any
Use for production workloads where encryption is required for compliance.
Data protection policies
Name Type Hourly snapshots Daily snapshots Weekly snapshots Monthly snapshots Summary
default
System defined
6
2
2
0
Use for standard workloads requiring short-term recovery points without long-term retention overhead.
3month-hourly
System defined
23
6
4
3
Use for regulated or business-critical workloads requiring granular intraday recovery points and three months of historical retention.
