NetApp Console local deployment
NetApp Console local deployment platform access roles
Contributors netapp-tonias netapp-ml94669
Assign platform roles to users to grant permissions to manage the NetApp Console local deployment, assign roles, add users, create fleets, and manage user authentication.
Example for organization roles for a large multi-national organization
XYZ Corporation organizes data storage access by region—North America, Europe, and Asia-Pacific—providing regional control with centralized oversight.
The Organization admin in XYZ Corporation's Console local deployment creates an initial organization and separate folders for each region. The Folder or fleet admin for each region organizes fleets (with associated resources) within the region's folder.
Regional admins with the Folder or fleet admin role actively manage their folders by adding resources and users. These regional admins can also add, remove, or rename folders and fleets they manage. The Organization admin inherits permissions for any new resources, maintaining visibility of storage usage across the entire organization.
Within the same organization, one user is assigned the Federation admin role to manage the federation of the organization with their corporate IdP. This user can add or remove federated organizations, but cannot manage users or resources within the organization. The Organization admin assigns a user the Federation viewer role to check federation status and view federated organizations.
The following tables indicate the actions that each Console local deployment platform role can perform.
Organization administration roles
Task Organization admin Folder or fleet admin
Create, modify or delete systems from the Console local deployment (add or discover systems)
Yes
Yes
Create folders and fleets, including deleting
Yes
No
Rename existing folders and fleets
Yes
Yes
Assign roles and add users
Yes
Yes
Associate resources with folders and fleets
Yes
Yes
Register for support and submit cases through the Console
Yes
Yes
Use data services that are not associated with an explicit access role
Yes
Yes
View the Audit page and notifications
Yes
Yes
Configure LLM integration and enable the Console assistant
Yes
No
Configure notification delivery and email server settings
Yes
No
Federation roles
Task Federation admin Federation viewer
Create and update directory service integrations
Yes
No
View federations and their details
Yes
Yes
Super admin and viewer roles
The Super admin role provides full access to manage Console features, storage, and data services. This role suits those overseeing administration and governance. In contrast, the Super viewer role offers read-only access, ideal for auditors or stakeholders who need visibility without making changes.
Organizations should use Super admin access sparingly to minimize security risks and align with the principle of least privilege. Most organizations should assign fine-grained roles with only the necessary permissions to reduce risk and improve auditability.
Example for super roles
ABC Corporation has a small team of five that leverages the NetApp Console for data services and storage management. Instead of distributing multiple roles, they assign the Super admin role to two senior team members who handle all administrative tasks, including user management and resource configuration. The remaining three team members are assigned the Super viewer role, allowing them to monitor storage health and data service status without the ability to modify settings.
Role Inherited roles
Super admin
  • Organization admin
  • Folder or fleet admin
  • Backup and recovery super admin
  • Storage admin
Super viewer
  • Organization viewer
  • Backup viewer
  • Storage viewer
