Supported LLM providers and models in NetApp Console local deployment
NetApp Console local deployment supports OpenAI, OpenAI-compatible, and Anthropic LLM provider types. The models you can select depend on the provider type and endpoint you configure.
This documentation regarding connecting an LLM to the Console assistant to enable AI features is provided as a technology preview. With this preview offering, NetApp reserves the right to modify offering details, contents, and timeline before General Availability. |
Choose a model that matches your performance, cost, and governance requirements.
See how provider type affects model availability
The provider type you choose determines which models appear in the Console local deployment model list:
OpenAI — provides models for direct OpenAI integration.
OpenAI-compatible proxy — to use an enterprise gateway or proxy service to connect to supported models.
Anthropic — provides models for direct Anthropic integration.
The models you see can vary based on endpoint configuration, proxy or gateway behavior, release support, and organizational policy. Provider types differ by the endpoint you connect to and the models that endpoint exposes, not the transport protocol.
Supported OpenAI models
GPT-5.4
GPT-5.5
Supported Anthropic models
Claude Sonnet 4.6
Claude Opus 4.6, 4.7 & 4.8
