NetApp Console local deployment
Manage member access in NetApp Console local deployment
Contributors netapp-tonias netapp-ml94669
In NetApp Console local deployment, review or change a user's roles across multiple folders or fleets, such as checking everything a storage engineer can access, adding a new role in another region, or removing that user's access when responsibilities change.
Required access roles
Super admin, Organization admin, or Folder or fleet admin (for folders and fleets that they are administering). Learn about access roles.
You can view and manage access in two ways depending on your needs. If you want to view the roles that a particular user has across all the fleet in your organization, use the Members page.
If you want to confirm who can access a specific fleet, review the members assigned to that fleet instead. Manage fleet access assignments.
To add a new member, service account, or directory user and assign their first role, use the onboarding task instead. Add members and assign roles.
Understand how access is granted in NetApp Console
NetApp Console uses role-based access control (RBAC) to manage member permissions. You can assign predefined roles at the organization, folder, or fleet level, depending on the scope of access that a member needs.
Using role inheritance
A role that you assign at the organization or folder level is inherited by the child scopes beneath it, so change an inherited assignment at the higher scope where you originally granted it.
View roles assigned to a member
Confirm exactly which roles a member holds and at which scope before you make a change. For example, check whether a teammate already has the Storage admin role on the Production-EU-West fleet.
If you have the Folder or fleet admin role, the page displays all members in the organization. However, you can view and manage permissions only for the folders and fleets that you administer. Learn about Folder or fleet admin actions in NetApp Console local deployment.
  1. From the Members page, navigate to a member in the table, select An icon that is three side-by-side dots and then select View details.
  2. In the table, expand the respective row for organization, folder, or fleet where you want to view the member's assigned role and select View in the Role column.
Assign or modify member access
You can adjust a member's access whenever responsibilities change. For example, when a teammate takes on backup duties for a second region, add the Backup and Recovery admin role on that region's fleet without touching their existing storage roles.
Add an access role to an existing member
Grant a member an additional role at the organization, folder, or fleet level when their responsibilities expand. For example, give a Storage admin the Backup and recovery admin role at the organization level so they can manage backup and recovery tasks across every fleet without losing their existing storage permissions.
You can assign a member an access role for your organization, folder, or fleet.
Members can have multiple roles within the same fleet and in different fleets. For example, smaller organizations may assign all available access roles to the same user, while larger organizations may have users do more specialized tasks. Alternatively, you could also assign one user the Ransomware resilience admin role at the organization level. In that example, the user would be able to perform Ransomware resilience tasks on all fleets within your organization.
Your access role strategy should align with the way you have organized your NetApp resources.
Steps
  1. Select Administration > Identity and access.
  2. Select Members.
  3. Select one of the member tabs: Users, Directory users, or Service accounts.
  4. Select the actions menu an icon with three vertical dots next to the member that you want to assign a role and select Add a role.
  5. To add a role, complete the steps in the dialog box:
    • Select an organization, folder, or fleet: Choose the level of your resource hierarchy that the member should have permissions for.
      If you select the organization or a folder, the member will have permissions to everything that resides within the organization or folder.
    • Select a category: Choose a role category. Learn about access roles.
    • Select a Role: Choose a role that provides the member with permissions for the resources that are associated with the organization, folder, or fleet that you selected.
    • Add role: If you want to provide access to additional folders or fleets within your organization, select Add role, specify another folder or fleet or role category, and then select a role category and a corresponding role.
  6. Select Add new roles.
Change a member's assigned role
Replace a member's existing role with a different one when their responsibilities shift. For example, when a Storage viewer on the Production-US-East fleet needs the Storage admin role instead.
Note Each user must have at least one role. You can't remove all roles from a user. If you need to remove all roles, delete the user from your organization.
Steps
  2. Select Members.
  4. From the Members page, navigate to a member in the table, select An icon that is three side-by-side dots and then select View details.
  5. In the table, expand the respective row for organization, folder, or fleet where you want to change the member's assigned role and select View in the Role column to view the roles assigned to this member.
  6. You can change an existing role for a member or remove a role.
    1. To change a member's role, select Change next to the role you want to change. You can only change a role to a role within the same role category. For example, you can change from one data service role to another. Confirm the change.
    2. To unassign a member's role, select An icon that resembles a trash can next to the role to unassign the member the respective role. You'll be asked to confirm the removal.
Remove a member from your organization
Remove a member when they leave the organization or change roles in a way that ends their need for Console access. For example, when a contractor's engagement ends or an employee transfers to a team outside your Console organization.
Note
Directory users
Removing a user from your directory prevents that user from authenticating. You should also remove the user from your Console organization to keep the member list accurate and to remove any roles that were assigned in Console local deployment.
Steps
  2. Select Members.
  4. From the Members page, navigate to a member in the table, select An icon that is three side-by-side dots then select Delete user.
  5. Confirm that you want to remove the member from your organization.
