Troubleshoot LLM integration in NetApp Console local deployment
Diagnose LLM integration failures in NetApp Console local deployment to restore Console assistant access and reliable responses for storage guidance and operations.
This documentation regarding connecting an LLM to the Console assistant to enable AI features is provided as a technology preview. With this preview offering, NetApp reserves the right to modify offering details, contents, and timeline before General Availability. |
If you have not completed setup, see Connect your LLM and enable the NetApp Console assistant.
Triage LLM integration issues quickly
Validate AI Tools configuration in Administration > AI Tools.
Confirm provider type, endpoint URL, API key, selected model, and outbound network access.
Validate assistant availability on the dashboard.
Confirm the Console assistant button appears for expected users and organizations.
Validate runtime behavior.
Run a simple read-only request and confirm provider endpoint reachability, model availability, and provider service health.
Troubleshoot by symptom
| Symptom | Likely cause | What to check | Next action |
Save or test fails in AI Tools |
Configuration or connectivity mismatch |
Provider type, endpoint URL, API key format, selected model, and outbound access |
Correct the value that fails validation and save again |
Console assistant button is missing |
Unhealthy integration status |
Successful AI Tools save, integration status, and expected access role |
Refresh the session and verify with a known-good admin account |
Assistant opens but request fails |
Provider or runtime path issue |
Endpoint reachability, model availability on that endpoint, provider limits, and temporary provider status |
Retry after fixing endpoint/model mismatch or provider-side limit issues |
Assistant response is slow or inconsistent |
Prompt size, endpoint performance, or network/proxy instability |
Short prompt test, provider service health, and network/proxy stability |
Use a shorter prompt, try another supported model, and stabilize network or proxy routing |
Respond to LLM credential exposure or misuse
If you suspect API key exposure or unauthorized use:
Revoke the existing API key in your provider system.
Create a new API key.
Update the key in Administration > AI Tools.
Verify successful reconnection with a read-only assistant test.
