NetApp Console local deployment
Create storage classes in NetApp Console local deployment
Contributors netapp-ml94669 netapp-tonias
Create a storage class in the NetApp Console local deployment to standardize how storage is provisioned and governed across your fleets. A storage class is a reusable template that bundles storage class policies—such as performance targets, capacity behavior, security requirements, and data protection schedules—into a single named definition.
When users (or automation) provision a volume or LUN using a storage class, NetApp Console local deployment applies the class's policies automatically. After provisioning, Console local deployment continuously monitors workloads against the storage class to detect drift and can guide or automate remediation to restore compliance.
Before you begin
  • Discover at least one ONTAP cluster so Console local deployment has targets for placement recommendations.
  • Ensure you have the Organization admin role (or a role that grants storage class management permissions in your environment).
  • Create (or identify) the storage class policies you plan to use—performance, capacity, security, and data protection—because storage classes are assembled from policies.
You must have the Organization admin or Folder or fleet admin role to add a storage class.
Steps
  1. Select Storage > Management.
  2. Select Storage classes.
  3. Select Add.
  4. Under Basic information, enter the following:
    • Storage class name: Enter a unique name for the storage class.
    • Description: (Optional) Enter a description of the storage class.
    • Recommended apps: (Optional) Enter a list of recommended apps for the storage class.
  5. Under Storage policies, select one or more policies to associate with the storage class.
  6. Select Add.
Customize an existing storage class
You must have the Organization admin or Folder or fleet admin role to customize an existing storage class.
Steps
  3. For the storage class you want to customize, select …, and then select Duplicate.
  4. Under Basic information, update the following as required:
  6. Select Add.
Edit a user-defined storage class
You must have the Organization admin or Folder or fleet admin role to edit a user-defined storage class.
Steps
  3. For the storage class you want to edit, select …, and then select Edit.
  4. Under Basic information, edit the following as required:
  6. Select Edit.
Delete a user-defined storage class
You must have the Organization admin or Folder or fleet admin role to delete a user-defined storage class.
Steps
  3. For the storage class you want to delete, select …, and then select Delete.
  4. Select Delete.
    Note that this action cannot be undone. If you delete a storage class that is currently in use, any volumes or LUNs provisioned with that class will continue to operate but will no longer be associated with the deleted class.
