NetApp Console setup and administration
Learn about verified organizations in NetApp Console
Contributors netapp-tonias
A verified organization links your organization in the NetApp Console to your NetApp business account identity (for example, a CMAT ID). This helps the Console apply a consistent organization identity and governance model across NetApp systems.
Why verify your organization
Verifying your organization can help you:
  • Align your Console organization with your NetApp business account identity.
  • Improve consistency for administration, reporting, and support workflows.
  • Reduce ambiguity when your teams work across multiple NetApp services.
  • Support governance controls that depend on a trusted organization identity.
What changes after verification
After your organization is verified:
  • The organization is associated with a NetApp business account identity.
  • The Console can treat that organization identity as authoritative for business-level mapping.
  • Some organization profile changes might be restricted in the Console if they are managed by the source system.
Before you verify
Before you verify your organization, confirm the following:
  • You have the required administrative role for your organization.
  • You have the organization details needed for verification.
  • You have coordinated with your NetApp account team if business-account mapping needs validation.
