NetApp Console setup and administration
Transparent proxy commands for the Console agent in NetApp Console
Contributors netapp-tonias
You can use the Console agent maintenance console to configure a Console agent to use a transparent proxy server.
Access the agent maintenance console
You can access the maintenance console from the Console agent host. Navigate to the following directory:
/opt/application/netapp/service-manager-2/agent-maint-console
View help for any command
To view help for any command, append --help to the command. For example, to view help for the proxy add command, use the following command:
./agent-maint-console proxy add --help
proxy get
The proxy get command displays information about the current transparent proxy server configuration. To view the current transparent proxy server configuration, use the following command:
Proxy get example
./agent-maint-console proxy get
proxy add
The proxy add command configures the agent to use a transparent proxy server.
-c <certificate file>
Specifies the path to the certificate file for the proxy server. The certificate file must be in PEM format. Ensure that the certificate file is in the same directory as the command or specify the full path to the certificate file.
Proxy add example
To add a transparent proxy server, use the following command, where /home/ubuntu/myCA1.pem is the path to the certificate file for the proxy server. The certificate file must be in PEM format:
./agent-maint-console proxy add -c /home/ubuntu/myCA1.pem
proxy update
The proxy update command allows you to update the certificate of a transparent proxy.
-c <certificate file> specifies the path to the certificate file for the proxy server. The certificate file must be in PEM format.
Proxy update example
To update the certificate for a transparent proxy server, use the following command, where /home/ubuntu/myCA1.pem is the path to the new certificate file for the proxy server. The certificate file must be in PEM format:
./agent-maint-console proxy update -c /home/ubuntu/myCA1.pem
proxy remove
The proxy remove command removes the transparent proxy server configuration from the agent.
Proxy remove example
To remove the transparent proxy server, use the following command:
./agent-maint-console proxy remove
