NetApp Console setup and administration
NetApp Backup and Recovery roles in NetApp Console
Contributors netapp-tonias netapp-mwallis
You can assign the following roles to users to provide them access to NetApp Backup and Recovery within the Console. Backup and Recovery roles give you the flexibility to assign users a role specific to the tasks they need to accomplish within your organization. How you assign roles depends on your own business and storage management practices.
The service uses the following roles that are specific to NetApp Backup and Recovery.
  • Backup and Recovery super admin: Perform any actions in NetApp Backup and Recovery.
  • Backup and Recovery backup admin: Perform backups to local snapshots, replicate to secondary storage, and back up to object storage actions in NetApp Backup and Recovery.
  • Backup and Recovery restore admin: Restore workloads using NetApp Backup and Recovery.
  • Backup and Recovery clone admin: Clone applications and data using NetApp Backup and Recovery.
  • Backup and Recovery viewer: View information in NetApp Backup and Recovery, but not perform any actions.
For details about all NetApp Console access roles, see access roles.
Roles used for common actions
The following table indicates the actions that each NetApp Backup and Recovery role can perform for all workloads.
Feature and action Backup and Recovery super admin Backup and Recovery backup admin Backup and Recovery restore admin Backup and Recovery clone admin Backup and Recovery viewer
Add, edit, or delete hosts
Yes
No
No
No
No
Install plugins
Yes
No
No
No
No
Add credentials (host, instance, vCenter)
Yes
No
No
No
No
View dashboard and all tabs
Yes
Yes
Yes
Yes
Yes
Start free trial
Yes
No
No
No
No
Initiate discovery of workloads
No
Yes
Yes
Yes
No
View license information
Yes
Yes
Yes
Yes
Yes
Activate license
Yes
No
No
No
No
View hosts
Yes
Yes
Yes
Yes
Yes
Schedules:
Activate schedules
Yes
Yes
Yes
Yes
No
Suspend schedules
Yes
Yes
Yes
Yes
No
Policies and protection:
View protection plans
Yes
Yes
Yes
Yes
Yes
Create, modify, or delete protection plans
Yes
Yes
No
No
No
Restore workloads
Yes
No
Yes
No
No
Create, split, or delete clones
Yes
No
No
Yes
No
Create, modify, or delete policy
Yes
Yes
No
No
No
Reports:
View reports
Yes
Yes
Yes
Yes
Yes
Create reports
Yes
Yes
Yes
Yes
No
Delete reports
Yes
No
No
No
No
Import from SnapCenter and manage host:
View imported SnapCenter data
Yes
Yes
Yes
Yes
Yes
Import data from SnapCenter
Yes
Yes
No
No
No
Manage (migrate) host
Yes
Yes
No
No
No
Configure settings:
Configure log directory
Yes
Yes
Yes
No
No
Associate or remove instance credentials
Yes
Yes
Yes
No
No
Buckets:
View buckets
Yes
Yes
Yes
Yes
Yes
Create, edit, or delete bucket
Yes
Yes
No
No
No
Roles used for workload-specific actions
The following table indicates the actions that each NetApp Backup and Recovery role can perform for specific workloads.
Kubernetes workloads
This table indicates the actions that each NetApp Backup and Recovery role can perform for actions specific to Kubernetes workloads.
Feature and action Backup and Recovery super admin Backup and Recovery backup admin Backup and Recovery restore admin Backup and Recovery viewer
View clusters, namespaces, storage classes, and API resources
Yes
Yes
Yes
Yes
Add new Kubernetes clusters
Yes
Yes
No
No
Update cluster configurations
Yes
No
No
No
Remove clusters from management
Yes
No
No
No
View applications
Yes
Yes
Yes
Yes
Create and define new applications
Yes
Yes
No
No
Update application configurations
Yes
Yes
No
No
Remove applications from management
Yes
Yes
No
No
View protected resources and backup status
Yes
Yes
Yes
Yes
Create backups and protect applications with policies
Yes
Yes
No
No
Unprotect apps and delete backups
Yes
Yes
No
No
View recovery points and resource viewer results
Yes
Yes
Yes
Yes
Restore applications from recovery points
Yes
No
Yes
No
View Kubernetes backup policies
Yes
Yes
Yes
Yes
Create Kubernetes backup policies
Yes
Yes
Yes
No
Update backup policies
Yes
Yes
Yes
No
Delete backup policies
Yes
Yes
Yes
No
View execution hooks and hook sources
Yes
Yes
Yes
Yes
Create execution hooks and hook sources
Yes
Yes
Yes
No
Update execution hooks and hook sources
Yes
Yes
Yes
No
Delete execution hooks and hook sources
Yes
Yes
Yes
No
View execution hook templates
Yes
Yes
Yes
Yes
Create execution hook templates
Yes
Yes
Yes
No
Update execution hook templates
Yes
Yes
Yes
No
Delete execution hook templates
Yes
Yes
Yes
No
View workload summary and analytics dashboards
Yes
Yes
Yes
Yes
View StorageGRID buckets and storage targets
Yes
Yes
Yes
Yes
