Cloud Volumes ONTAP access roles in NetApp Console
You can assign the following roles to users to provide them access to Cloud Volumes ONTAP within NetApp Console.
Access roles for Cloud Volumes ONTAP are available when you are running a Console agent version 4.9.0 or later. |
Cloud Volumes ONTAP admin: Provides full access to all Cloud Volumes ONTAP operations.
Cloud Volumes ONTAP contributor: Provides similar access as the Cloud Volumes ONTAP admin role, except for operations that delete or remove resources or turn systems on or off. Contributors can perform operations such as adding systems, managing replication, and editing volume and system settings, but can't delete systems, volumes, aggregates, or replication relationships.
Cloud Volumes ONTAP operator: Performs important storage operations, such as discovering and managing Cloud Volumes ONTAP systems, including adding volumes, aggregates, snapshots, and replications, modifying some configurations, and upgrading Cloud Volumes ONTAP versions.
Cloud Volumes ONTAP viewer: Provides read-only access to Cloud Volumes ONTAP information. This role can't perform any active operations. Some tabs and screens containing configuration information might be unavailable to viewers.
For details about all NetApp Console access roles, see access roles.
How role changes take effect
Wait up to one hour for new or updated role assignments to take effect. Cloud Volumes ONTAP refreshes role assignments every hour.
Cloud Volumes ONTAP role permissions
The following table indicates the actions that each role can perform.
| Feature and action | Cloud Volumes ONTAP admin | Cloud Volumes ONTAP contributor | Cloud Volumes ONTAP operator | Cloud Volumes ONTAP viewer |
Systems page: |
Enter a system |
Yes |
Yes |
Yes |
Yes |
View a volume |
Yes |
Yes |
Yes |
Yes |
Discover a system |
Yes |
Yes |
Yes |
No |
Add a volume |
Yes |
Yes |
Yes |
No |
Use Replication (not applicable to FSx for ONTAP or on-premises systems) |
Yes |
Yes |
Yes |
No |
Use drag-and-drop for Replication (with Cloud Volumes ONTAP as the source or destination) |
Yes |
Yes |
Yes |
No |
Add a system |
Yes |
Yes |
No |
No |
Access Optimized cost and performance |
Yes |
Yes |
No |
No |
Open System Manager |
Yes |
No |
No |
No |
Turn on Cloud Volumes ONTAP |
Yes |
No |
No |
No |
Remove a system |
Yes |
No |
No |
No |
Agents page: |
View Cloud Volumes ONTAP settings |
Yes |
Yes |
Yes |
Yes |
Edit Cloud Volumes ONTAP settings |
Yes |
Yes |
No |
No |
Overview tab: |
Add a volume |
Yes |
Yes |
Yes |
No |
Add an aggregate |
Yes |
Yes |
Yes |
No |
Use Upgrade now |
Yes |
Yes |
Yes |
No |
Update the ONTAP version |
Yes |
Yes |
Yes |
No |
Edit CIFS setup from the pencil menu |
Yes |
Yes |
Yes |
No |
Yes |
No |
No |
No |
Use the On/Off button |
Yes |
No |
No |
No |
Set a password |
Yes |
No |
No |
No |
Remove the system from the workspace |
Yes |
No |
No |
No |
Delete the system |
Yes |
No |
No |
No |
Edit the following using the pencil icon on the right pane:
Yes |
Yes |
No |
No |
Volumes tab: |
Add a volume |
Yes |
Yes |
Yes |
No |
Clone a volume |
Yes |
Yes |
Yes |
No |
Create a snapshot copy |
Yes |
Yes |
Yes |
No |
Edit volume settings |
Yes |
Yes |
No |
No |
Delete a volume |
Yes |
No |
No |
No |
Restore from a snapshot copy |
Yes |
Yes |
No |
No |
Change the disk type |
Yes |
Yes |
No |
No |
Change the tiering policy |
Yes |
Yes |
No |
No |
Aggregates tab: |
Add an aggregate |
Yes |
Yes |
Yes |
No |
Add a volume |
Yes |
Yes |
Yes |
No |
Increase capacity |
Yes |
Yes |
No |
No |
Delete an aggregate |
Yes |
No |
No |
No |
Replication page (with Cloud Volumes ONTAP as the source or destination): |
Break replication |
Yes |
Yes |
No |
No |
Resync replication |
Yes |
Yes |
No |
No |
Reverse resync replication |
Yes |
Yes |
No |
No |
Edit the schedule |
Yes |
Yes |
No |
No |
Edit the maximum transfer rate |
Yes |
Yes |
No |
No |
Update replication |
Yes |
Yes |
No |
No |
Delete replication |
Yes |
No |
No |
No |
