Import your federation to NetApp Console
If you have previously set up federation through NetApp Cloud Central (an external application to the NetApp Console) the Federation page prompts you to import your existing federated connection to the Console so you can manage it in the new interface. You can then take advantage of the latest enhancements without having to recreate your federated connection.
After you import your existing federation, you can manage the federation from the Federations page. Learn more about managing federations. |
Required role
Organization admin or Federation admin. Learn more about access roles.
Steps
Select Administration > Identity and access.
Select the Federation tab.
Select Import Federation.
