NetApp Console setup and administration
Federate NetApp Console with PingFederate
Contributors netapp-tonias
Federate with your PingFederate IdP provider to enable single sign-on (SSO) for the NetApp Console. This allows users to log in using their corporate credentials.
Required roles
The Federation admin role is required to create and manage federations. Federation viewer can view the Federation page. Learn more about access roles.
Note You can federate with your corporate IdP or with the NetApp Support Site. NetApp recommends choosing one or the other, but not both.
NetApp supports service provider-initiated (SP-initiated) SSO only. You need to first configure the identity provider to trust NetApp as a service provider. Then, you can create a connection in the Console that uses the identity provider's configuration.
You can set up a federated connection with PingFederate to enable single sign-on (SSO) for the Console. The process involves configuring your PingFederate server to trust the Console as a service provider and then creating the connection in the Console.
Before you begin
  • An IdP account with administrative privileges is required. Coordinate with your IdP administrator to complete the steps.
  • Identify the domain you want to use for federation. You can use your email domain or a different domain that you own. If you want to use a domain other than your email domain, you must first verify the domain in the Console. For instructions, see Verify your domain in NetApp Console.
Steps
  1. Select Administration > Identity and access.
  2. Select Federation to view the Federations page.
  3. Select Configure new federation.
  4. Enter your domain details:
    1. Choose whether you want to use a verified domain or your email domain. The email domain is the domain associated with the account you are logged in with.
    2. Enter the name of the federation you are configuring.
    3. If you choose a verified domain, select the domain from the list.
  5. Select Next.
  6. For your connection method, choose Provider and then select PingFederate.
  7. Select Next.
  8. Configure your PingFederate server to trust NetApp as a service provider. You need to do this step on your PingFederate server.
    1. Use the following values when configuring PingFederate to trust the NetApp Console:
      • For the Reply URL or Assertion Consumer Service (ACS) URL, use https://netapp-cloud-account.auth0.com/login/callback
      • For the Logout URL, use https://netapp-cloud-account.auth0.com/logout
      • For Audience/Entity ID, use urn:auth0:netapp-cloud-account:<fed-domain-name-pingfederate> where <fed-domain-name-pingfederate> is the domain name for the federation. For example, if your domain is example.com, the Audience/Entity ID would be urn:auth0:netapp-cloud-account:fed-example-com-pingfederate.
    2. Copy the PingFederate server URL. You will need this URL when creating the connection in the Console.
    3. Download the X.509 certificate from your PingFederate server. It needs to be in Base64-encoded PEM format (.pem, .crt, .cer).
  9. Return to the Console, and select Next to create the connection.
  10. Create the connection with PingFederate.
    1. Enter the PingFederate server URL that you copied in the previous step.
    2. Upload the X.509 signing certificate. The certificate must be in PEM, CER, or CRT format.
  11. Select Create connection. The system creates the connection in a few seconds.
  12. Select Next.
  13. Select Test connection to test your connection. You are directed to a login page for your IdP server. Log in with your IdP credentials. After you log in, go back to the Console to enable the connection.
    Note When using the Console in restricted mode, copy the URL to either an incognito browser window or a separate browser to log in to your IdP.
  14. In the Console, select Next to review the summary page.
  15. Set up notifications.
    Choose between seven days and 30 days. The system emails expiry notifications and shows them in the Console to any user with the following roles: Super admin, Org admin, Federation admin, and Federation viewer.
  16. Review the federation details and then select Enable federation.
  17. Select Finish to complete the process.
After you enable the federation, users log in to the NetApp Console using their corporate credentials.
