NetApp Console setup and administration
Verify your email domain for federation in NetApp Console
Contributors netapp-tonias
If you want to federate with a domain that is different from your email domain, you must first verify that you own the domain. You can only use verified domains for federation.
Required roles
The Federation admin role is required to create and manage federations. Federation viewer can view the Federation page. Learn more about access roles.
Verifying your domain involves adding a TXT record to your domain's DNS settings. This record is used to prove that you own the domain and allows the NetApp Console to trust the domain for federation. You may need to coordinate with your IT or network administrator to complete this step.
For example, if using Microsoft Entra ID, you can follow the steps in the Microsoft documentation Add a domain with Microsoft Entra ID.
Steps
  1. Select Administration > Identity and access.
  2. Select Federation to view the Federations page.
  3. Select Configure new federation.
  4. Select Verify domain ownership.
  5. Enter the domain that you want to verify and select Continue.
  6. Copy the TXT record that is provided.
  7. Go to your domain's DNS settings and configure the TXT value that was provided as a TXT record for your domain. Work with your IT or network administrator if needed.
  8. After the TXT record is added, return to the Console and select Verify.
