Monitor or audit IAM activity in NetApp Console
If you need to monitor or audit an action that was completed related to identity and access, you can view details from the Audit page. For example, you might want to verify who added a member to an organization or that a project was deleted successfully.
Steps
Select Administration > Audit.
On the Audit page, use the filters to narrow the results. Select Service and then select Tenancy.
Use any of the other filters to change which actions display in the table.
For example, you can use the User filter to show actions related to a specific user account.
