Enforce ONTAP permissions for ONTAP System Manager in NetApp Console
By default, the Console agent credentials allow users to access the Advanced View (ONTAP System Manager). You can prompt users for their ONTAP credentials instead. This ensures that a user's ONTAP permissions are applied when they work with ONTAP clusters in both Cloud Volumes ONTAP and ONTAP on-premises clusters.
You must have the Organization admin role to edit Console agent settings. |
Steps
Select Administration > Agents.
On the Overview page, select the action menu for a Console agent and select Edit agent.
The Console agent must be active to edit it.
Expand the Force Credentials option.
Select the checkbox to enable the Force Credentials option and then select Save.
Verify that the Force Credentials option is enabled.
